Issue with auto roof
#1 Wes Harr
Wes Harr
  • 29 posts
Posted 30 September 2022 - 09:50 AM
Hello all,
I have a quick question on an issue I run into often, when I use "auto roof" when intersecting with another roof, it looks correct on the roof plan, but in elevation/3d mode it ends up "peeking" through the roof it intersects with, so I usually end up doing a vertical intersect and I draw a hole in the roof, curious if I'm missing some setting or is it just broken.
Thanks!
#2 Joseph Smith
  • 853 posts
Posted 30 September 2022 - 09:56 AM
I'd move that upper lollypop down to the same wall that the roof plane is attached, make sure the lollypop says 'intersect and auto pitch'  do a regen or cleanup and it should be identifying the correct plane below it  if that doesn't work then you may have to do 'intersect and vertical plane and cut some holes..
good luck, keep messing with it, eventually it'll work.
  • Wes Harr likes this
#3 Wendall Hilty
Wendall Hilty
  • 146 posts
Posted 30 September 2022 - 10:03 AM
The reason this is happening is because the wall of that section is lower than the other one. The part that's poking through is angled up from the edge of the roof on the lower wall. Auto roof doesn't always play nicely on complex roofs.
#4 Wes Harr
Wes Harr
  • 29 posts
Posted 30 September 2022 - 10:50 AM
Hey Joseph & Wendell, Thanks for the help, I was wondering if the different wall heights was the issue.
#5 Wendall Hilty
Wendall Hilty
  • 146 posts
Posted 30 September 2022 - 10:58 AM
There are ways to work with the lower wall. You could try tracing the lower roof seperately and seeing if that helps.
#6 Fred Russell
Fred Russell
  • 786 posts
Posted 01 October 2022 - 07:31 AM
seems like ignor wall sometimes helps
