Foundation
#1 Ron Sirolli
Ron Sirolli
  • 262 posts
Posted 02 November 2022 - 01:57 PM
i am trying to build a new foundation wall 16"x8" footing with 3- courses of 8" block and 2-courses of 6" block to create a ledge for the concrete floor and i seam not
to be able to see the 6"line when in floor plan i am not sure if i am suppose to none or not
thanks Ron
#2 Wendall Hilty
Wendall Hilty
  • 136 posts
Posted 02 November 2022 - 03:15 PM
You won't see a line unless you take some special steps. Here is one way it can be done.
Go to the wall definition and click on the options tab at the top. Check display height and set it to such a height that it brings the green line in the section view up into the six inch block at the top. This is where the wall will display on the print.
Attached File  Image 2.PNG   27.33KB   0 downloads
Now we have the problem that the wall will only display the six inch block and not the 8 inch block. To get around this problem we can place an airspace against the inside of the six inch block. Add the airspace and set it to the right size. Click on the fill tab and check the texture visible box for the airspace. Select the desired texture pattern and turn on the shading and set it to the correct color if neccessary.
Attached File  Image 4.PNG   33.87KB   0 downloads
Attached File  Image 5.PNG   12.41KB   0 downloads
Edit...
I thought of a faster way to do it that will save a few steps. Put the two inch airspace inside the eight" block.
  • Sean Tobin likes this
#3 Ron Sirolli
Ron Sirolli
  • 262 posts
Posted 02 November 2022 - 03:39 PM
thanks Wendall i did figure out finial i appreate very much
thanks Ron
Posted 02 November 2022 - 07:42 PM
Wendall, the easiest way to show a line in the wall definition is to use a 0.000" thick full height NONE material where you want to show the line.
  • Jim Johnson, David Zawadzki, Stephan Page and 1 other like this
#5 Wendall Hilty
Wendall Hilty
  • 136 posts
Posted 03 November 2022 - 05:56 AM
That's a good idea Keith. Somehow I find the hard way of doing things.  :)
