How does one go about to create the gable overhangs shown in the attached photo?
IMG_0408.jpg 208.17KB
8 downloads
Posted 14 December 2022 - 04:08 PM
8 downloads
Posted 14 December 2022 - 04:15 PM
Gable end roof lollypops attached to phantom or hidden walls to the inside of the home. Have fun! after you do one, the others are easy. I usually start with a line determining the angle i'm looking for then make the phantom wall right on the line.
Posted 14 December 2022 - 09:51 PM
Posted 15 December 2022 - 09:10 AM
Posted 15 December 2022 - 10:26 AM
One method I use for a prow roof (pointed gable) when I have a flat gable wall is to set the gable overhang to the point distance and then cut triangle holes in the roof to get the shape. One problem I experienced with this is that the soffit does not render underneath when I use this method. I would prefer this technique than trying to add extra hidden walls, layering them, etc, but I wonder if anyone else used this method I am explaining and had the same issue. I may have to use hidden walls if the missing soffit can't be fixed anytime soon.
SoftPlan →
General Questions →
"Double" RoofStarted by Eric Martin , 27 Jun 2025 ![]() |
SoftPlan →
SoftPlan 2026 →
Ceiling Wars: Part DeuxStarted by Jason Bloomingdale , 05 Jun 2025 ![]() |
SoftPlan →
SoftPlan 2026 →
Split Roof EdgesStarted by Jason Bloomingdale , 21 May 2025 ![]() |
SoftPlan →
General Questions →
Plate Heights in Roof ModeStarted by Steve Gray , 16 May 2025 ![]() |
SoftPlan →
SoftPlan 2024 →
Site Plan DimensionsStarted by Jason Bloomingdale , 10 Apr 2025 ![]() |
