Softplan Key Why not a pass code????
21 replies to this topic
#21 Bruce Jennings
Bruce Jennings
  • 10 posts
Posted 07 December 2023 - 06:37 PM
Joe wrote that 12 years ago. An eternity in tech.
Joe Stoddard has a classic response to what software is best…
https://forums.jlcon...-softplan/page3
At the end of the comments on page 3, Joe does a good job explaining the benefits of the hardware key
#22 David Edlin
David Edlin
  • 45 posts
Posted 09 December 2023 - 04:38 PM
Why not have the key as normal, and a limited number of times between, key use, where you can use a code unique for your key before you must use the key again ( 5 times to use the code). That gets every one out of a sticky patch, and a stop can be put on the system if both the key and code are used at the same time.
Hope that helps.
David Edlin
  • Gary McKeon and David Zawadzki like this
