Outline a note inside a table?
11 replies to this topic
#1 Richard Taylor
Richard Taylor
  • 179 posts
Posted 28 January 2023 - 09:51 AM
I can outline a note not in a table, is it possible to outline a note inside a table? I would like to have a circle around a number...possible?  Workaround?
#2 Wendall Hilty
Wendall Hilty
  • 136 posts
Posted 28 January 2023 - 02:30 PM
Create your table as desired then draw a circle using SHAPES and position it over the table as necessary.
#3 Richard Taylor
Richard Taylor
  • 179 posts
Posted 28 January 2023 - 03:27 PM
thanks... that will "work", but I'm hoping for something a little more permanent. Might have to do for now.
#4 Wendall Hilty
Wendall Hilty
  • 136 posts
Posted 30 January 2023 - 07:30 AM
If you are dealing with a small number, you could copy and paste something from this list. Unicode Circled Numbers ① ❷ ⓷ ALT Codes for Circled Numbers (lennyfacecopypaste.com)
#5 Richard Taylor
Richard Taylor
  • 179 posts
Posted 30 January 2023 - 09:05 AM
Better! Thanks for the idea.
#6 Mark Petri
  • 1,512 posts
Posted 30 January 2023 - 03:50 PM
You can also create and use any sort of symbol, speed note, etc. in a table. Try setting up the common numbers or whatever you want to use typically as one of those items and import them to the table by clicking on the toilet symbol in the top menu ribbon and going to wherever you have them saved.
  • Heath Foster likes this
#7 Richard Taylor
Richard Taylor
  • 179 posts
Posted 30 January 2023 - 09:52 PM
Mark - that one I've tried...unfortunately can't have a symbol and text in the same table cell  :(
#8 Matthew Dunson
Matthew Dunson
  • 172 posts
Posted 31 January 2023 - 09:19 AM
There also isn't an ability to scale any of the symbols within a table so it is kind of a limiting feature that I find it mostly useful for custom Electrical Schedules where the symbols are mostly uniform.
#9 Mark Petri
  • 1,512 posts
Posted 31 January 2023 - 09:37 AM
You would have to make the whole content of the cell a symbol or speed note, etc. But, yes, there are limitations.
#10 Tim Stockton
Tim Stockton
  • 313 posts
  • LocationWichita, KS
Posted 06 February 2023 - 10:21 AM
I just created an opening schedule (table) and clicked on a cell and then chose bold face for that cell.  It worked.  Would this do what you are needing?  You can also choose an entirely different font for that single cell.
#11 Richard Taylor
Richard Taylor
  • 179 posts
Posted 06 February 2023 - 10:22 AM
Thanks, but nope.
#12 Heath Foster
Heath Foster
  • 6 posts
Posted 06 February 2023 - 10:57 AM
Adding to Tim's idea you could download a font to display the circled numbers for a single column. I tried numberpile font and it seemed to work fine although the map the provide to show which letters correspond to which numbers isn't accurate for me. So you may have to search to find the number you are looking for.
Edit- actually it works fine. I wasn't paying attention to the capitalization.
