Row lock
16 replies to this topic
#1 Ron Sirolli
Ron Sirolli
  • 304 posts
Posted 22 February 2023 - 12:03 PM
How do you add a brick row lock on a porch slab
Thanks Ron
#2 Allen McDonnell
  • 1,208 posts
  • LocationIllinois
Posted 22 February 2023 - 04:08 PM
Solids, and then apply a texture that looks good.  The brick row lock will not look as nice as what we can do on openings.   I guess you could dbl up the solid to make the indention...but that would be cumbersome.
#3 Ron Sirolli
Ron Sirolli
  • 304 posts
Posted 23 February 2023 - 04:41 AM
Thanks Allen i did that but it will not show the brick line up in the row lock i found a single brick in symbles but can not figure out how to set
it up for indvisal pices
thanks Ron
#4 Philip Frank
  • 578 posts
Posted 23 February 2023 - 07:34 AM
Try these.
#5 Derrik Bauer
Derrik Bauer
  • 9 posts
  • LocationCentral Iowa
Posted 23 February 2023 - 07:53 AM
Base Trim is much faster.  You'll need to change the finish so you don't end up with brick baseboards in the house.  If you are using Softlist you may need to make some changes as well.
  • Attached File  1.jpg   64.48KB   1 downloads
#6 Ron Sirolli
Ron Sirolli
  • 304 posts
Posted 24 February 2023 - 06:59 AM
Thanks Philip i did that but it dose not show up i did a cube and added the solder am i doing something wrong
thanks Ron
#7 John Jones
John Jones
  • Administrators
  • 180 posts
Posted 24 February 2023 - 08:44 AM
Try the Banding command.
  • Mike Adams likes this
#8 Thomas Parker
Thomas Parker
  • 51 posts
Posted 24 February 2023 - 09:44 AM
Is this the look you want?
Softplan usually has several ways to accomplish the same thing, but on the site plan I would place four  solid polygons with mitered corners. Make sure the two opposite sides are solid1 and solid 2 so when you surface edit the two sides can turn the brick solider 90 degrees. Then draw the outline for the 'Site Work' 'Concrete' . You'll need to tweak the elevations of the solids and on one of the solid textures of the brick solider options may need to check scale.
Hopefullly the photo uploaded
TOM
  • Allen McDonnell, David Zawadzki and Matthew Dunson like this
Tom Parker
TJP Designs and Const. LLC
v10 - v2020
#9 Ron Sirolli
Ron Sirolli
  • 304 posts
Posted 25 February 2023 - 05:50 AM
thanks everone i did figure it out with tech suport
#10 Keith Almond
Posted 25 February 2023 - 05:02 PM
Ron, can you explain what it was that you actually wanted, and what the solution was please?
#11 Ron Sirolli
Ron Sirolli
  • 304 posts
Posted 26 February 2023 - 08:56 AM
Keith i was trying to add a sholder corse on a porch slab i added a cube and then i added the sholder course to it but it did not show up in 3 d so i edit the surface and had to put a check in to display texture and that work
i got that from support i sent a ticket in and they told me what to do they are greate for the help they give
thanks Ron
#12 Bill Wimberley
Bill Wimberley
  • 622 posts
  • LocationSan Angelo, TX
Posted 26 February 2023 - 11:21 AM
I typically use walls for the brick around a porch. I have a special wall just for that.
  • David Franz likes this
#13 David Zawadzki
  • 736 posts
Posted 26 February 2023 - 11:30 AM
It would be nice if we could easily add borders to slabs.
#14 Keith Almond
Posted 26 February 2023 - 02:19 PM
thanks Ron
Thank you. That makes more sense now. The number of solutions posted, all seemed to fix a different problem.
#15 Ron Sirolli
Ron Sirolli
  • 304 posts
Posted 27 February 2023 - 05:47 AM
David that is what i did you just have to draw a cube arounf the edges ans paist the solder course to the cube
#16 David Zawadzki
  • 736 posts
Posted 27 February 2023 - 06:01 PM
If we could get some of the features and /or options that we have when drawing decks added to concrete slabs, it would be much appreciated.
Here’s some examples:
https://www.pinteres...70831884954391/
  • Chris Proost likes this
#17 David Zawadzki
  • 736 posts
Posted 28 February 2023 - 08:25 AM
And, we can add insulation under a slab by checking a box, how about adding another box to automatically add gravel underneath the slab and insulation?
