I have a roof plan I am 3D modeling for a friend and need help waking up some brain cells to figure out how to make parts of the gable overhangs extend out an additional 12 inches at the peak.
See attached roof plan:
Posted 24 March 2023 - 01:49 PM
Posted 24 March 2023 - 04:40 PM
I was hoping we could just break the roof, like we can now do with walls, and adjust the overhang.
Posted 24 March 2023 - 11:20 PM
Then try to hide the roof hole mess you have. for 2D live views. It is one way, but not perfect. Saving and cleaning up the roof layout linework when done is the cleanest way at the end. If for 3D only, the holes tend to work better than beams a lot of the time. If the roof below is the same roof as a gable above the holes will not work. Don't see any in your example that look like they will have that problem. Then you have to either break up roofs or use beams or walls that are hidden. Often best to move them out away from the main walls so referencing doesn't get messy.
Posted 25 March 2023 - 08:14 PM
I move my beams fully inside the structure, as that keeps the inside edge of the soffit fully within the exterior walls.
