Walls disappearing
Walls disappearing
#1 Rick Kingsbury
Rick Kingsbury
  • 171 posts
  • LocationSpearfish, SD
Posted 07 June 2023 - 09:30 AM
Anyone have exterior walls that disappear for no apparent reason?
I can't understand what would cause this.
#2 Myron Penner
Myron Penner
  • 57 posts
  • LocationAltona, MB Canada
Posted 07 June 2023 - 09:33 AM
Yes, I've had the same thing happen.  I thought it was just 'something I must have done'.
#3 Sam Morgan
  • 938 posts
Posted 07 June 2023 - 09:44 AM
happens occasionally here...cleanup usually fixes it
#4 Rick Kingsbury
Rick Kingsbury
  • 171 posts
Posted 07 June 2023 - 09:51 AM
OK. Thanks guys! I will give the cleanup a try!
#5 Allen McDonnell
  • 1,208 posts
  • LocationIllinois
Posted 07 June 2023 - 10:24 AM
Yes....delete any opening that is in the wall then hit undo....that works for me.
#6 Rick Kingsbury
Rick Kingsbury
  • 171 posts
Posted 07 June 2023 - 11:54 AM
After fooling around with it I found that reducing the wall joins fixed it.
  • John Jones likes this
#7 Dennis Asher
Dennis Asher
  • 247 posts
Posted 07 June 2023 - 01:19 PM
I had this happen on a job recently.  I sent a ticket to support and they fixed my problem within a day.  I don't like the way beams fillet and show on the 3d elevations.  I have tried in the past to make a beam that is wrapped with stucco and I just can't get them to fillet properly.  My work around is to use a stucco wall set to the height of what the beam would be and then offset to the appropriate height and uncheck cleanup.  I then put that wall on a hidden layer and turn off visibility.  That "beam wall" was making the house wall disappear.  Tech support had be reduce the join tolerances on the "beam wall" and that fixed my problem.
