I've upgraded to a new laptop and installed 2024. I've transfered my wall definitions successfully from the old machine but now at a loss on how to copy my keyboard shortcuts from my old laptop to the new install. I did not find any post on this particular issue so hoping someone can tell me if copying/ transfering is possible. Would be very time consuming to manually change all the defaults. There is probably an easy solution but I sure can't find it!
Keyboard Shortcuts
Started by
Brent Eichman
, Aug 20 2023 12:03 PM
1 reply to this topic
Posted 22 August 2023 - 11:04 AM
Brent- this should be posted in the v2024 area instead of the "guest" area. Anyway, go to System Options- Archive- and check the box for the 'keyboard shortcuts' under the Miscellaneous checkbox and do a "backup". Then, in your new install, go to the same place, check the 'keyboard shortcuts' again and do a "restore". Obviously when you are doing the backup portion you have to save it someplace where you can access it on your new laptop.
