Smaller PDF files
#1 GENE GILES
GENE GILES
  • 89 posts
Posted 16 September 2023 - 01:23 PM
Afternoon All -
Any great way to downsize PDF's we are doing a 358 unit apartment complex and the file is huge.
Gene
#2 Don Gibbons
Don Gibbons
  • 62 posts
Posted 17 September 2023 - 10:32 AM
Plan Sets will allow you to Export to a PDF and set the dpi which affects the file size. It defaults to 600dpi and I change it to 300dpi. This setting usually keeps my PDF's under 10Mb. You can drop it to 150dpi but I think the quality suffers at that point. If you're not using Plan Sets and are printing to a PDF printer, that setting falls to the driver you have installed IF it's available. I checked the Microsoft Print to PDF and it was not available.
#3 David Zawadzki
  • 734 posts
Posted 17 September 2023 - 12:06 PM
Here, we are required to submit plans online as individual sheets and those individual pdf’s may be bundled into a single zip file.
Would that work for you?
#4 GENE GILES
GENE GILES
  • 89 posts
Posted 18 September 2023 - 12:47 PM
We use plansets and have reduced the DPI to 300 and our systems are just hanging.
Gene
#5 Don Gibbons
Don Gibbons
  • 62 posts
Posted 18 September 2023 - 05:07 PM
Do you have any images in the plans? I have an image of my logo and there's a significant difference when I create the PDF with the border and without the border.
#6 Mark Petri
  • 1,874 posts
Posted 21 September 2023 - 08:34 AM
I find multi-format notes are the biggest contributor. Any imports of DWGs with lots of line segments or other drawings that are real busy also contribute.
