SoftPlan 2022 -Front,Rear,Left,Right Views
#1 Larry Hartensteiner
Larry Hartensteiner
  • 33 posts
Posted 12 October 2023 - 09:40 PM
When the views are displayed. The opposite view item are also displayed. For example looking a the Front view the back steps are also see but from the back side of the steps. Or a skirt on the rear porch is shown. I never had this happen in SoftPlan 2020.
Sure I can put a Building Option on the ones I don't want to see but than I have to repeatedly change back and forth. I can't figure out what I am doing differently from SoftPlan 2020???
#2 Philip Frank
  • 560 posts
Posted 13 October 2023 - 08:57 AM
Are your exterior walls defined as bearing walls? If not, SoftPlan considers them interior walls  and they do not show up on elevations.
#3 Bill Wimberley
Bill Wimberley
  • 468 posts
  • LocationSan Angelo, TX
Posted 13 October 2023 - 09:22 AM
I use Custom Visibilities for Building Options to handle that situation.
1. Assign the steps, brick ledges, etc. that you want to hide to a Building Option.
2. On the Plan Set Page right click the elevation you want to hide the items from.
3. Check Use Custom Visibilities
4. Select Edit Visibilities and turn the Building Option off. It will only affect that elevation.
