Structural Grid edits
#1 Rick Kingsbury
Rick Kingsbury
  • 170 posts
  • LocationSpearfish, SD
Posted 10 January 2024 - 03:53 PM
Does anyone know if we have the ability to edit the structural grids?
I have a plan from a steel company that I need to match letters & numbers to satisfy the structural engineer.
I need to change the numerals into letter & vice versa.
The builder also wants to add structural grids that are partial (for example 3.6 or 5.1).
It sure would be nice to do a simple edit!
Thanks in advance!!!
#2 Derk Burgers
Derk Burgers
  • 79 posts
  • LocationSioux Center, Iowa
Posted 11 January 2024 - 08:25 AM
I never use the structural grids, but decided to check them out -- I noticed you could turn the labels off and thought, well, if all else fails we can do the ole Softplan workaround and just turn labels off and manually note everything.
However, you can only turn 1 label at a time -- if you try to uncheck the Left, then uncheck the Right, it re-checks the Left.
In Drawing Options -> Framing Options, there is a group for auto-generated Wall Labels....I don't see anything for Structural Grids.
Seems like for custom labels you'd have to just use lines/notes.
#3 Jon Churchill
Jon Churchill
  • 421 posts
  • LocationThe Oaks, Australia
Posted 11 January 2024 - 02:37 PM
Rick,
Set the Drawing Options > Character Setup > Structural Grid font size to a small value eg, 0.1 Then add a note with a circle outline.
Jon
  • Rick Kingsbury, Gary McKeon and David Zawadzki like this
#4 David Zawadzki
  • 663 posts
Posted 11 January 2024 - 07:59 PM
Can you just import the engineers drawing on to a new sheet and then add it into your planset?
As for the builder, just tell him your software doesn't do partial grids, but you can place as many grid lines as needed.
#5 Rick Kingsbury
Rick Kingsbury
  • 170 posts
Posted 15 January 2024 - 04:22 PM
Thanks everyone for your input.
I decided to draw a masked letter/ number with a circle & size it to match.
It worked fine, just time consuming.
