Has anyone been able to create interior elevation cabinets that aren't all light and washed out when exported to PDF? If so, how did you do it?
The darker image is an interior elevation saved as a line drawing then placed on a plan set page and exported to PDF.
The lighter image is an interior elevation placed on a plan set page and exported to PDF.
No matter what settings I use I can't seem to get the live interior elevations to be dark and sharp like the line drawings.
Interior elevations
#1
Posted 27 January 2024 - 05:25 PM
Posted 30 January 2024 - 09:06 AM
Thanks Fred. When I use the Direct X 12 with lines set to 1 it looks good on screen but is washed out and light grey in the PDF. If I increase the lines to 10 it looks pretty good in the PDF but on screen the lines are very thick like they were drawn with a magic marker.
There doesn't seem to be a setting where it looks good on both the screen and in the PDF. Which is weird since I can get excellent results both on screen and in the PDF for exterior elevations.
#8
Posted 31 January 2024 - 05:42 PM
So this customer said to me: "Fred, the reason I had you come here at exactly 10 am is, if you put your head down on the floor right here and look across at this angle you can see a slight difference in the floor finish. The sun has to hit it just right, but you can see it." True story.
- Bill Wimberley and David Zawadzki like this
#10
Posted 06 February 2024 - 07:08 AM
Try putting them on a unique layer and select the "fade" option.
#11
Posted 08 February 2024 - 06:07 PM
Use model view of the kitchen and use Direct X 12. Increase the line width to what ever you want (1 looks good to me). Try your Annotated view now and place on the Plan Set.
Could you explain a bit more detail please? Where do you go to set to Direct x 12?
#12
Posted 08 February 2024 - 06:14 PM
Open up a 3D model, then options and then mode option.
#14
Posted 09 February 2024 - 06:55 AM
I opened the elevation view in the model mode, made all the changes as noted above, switched to annotated view and placed that view on the plan set. The lines do appear much darker then they will on the pdf file. I did not print the pdf file and felt no need to do so. Especially since your printer and my printer will print differently.
