Exterior wall join material issue
Exterior walls exterior wall material
#1 Steve Gray
Steve Gray
  • 11 posts
  • LocationWarner Robins, GA
Posted 01 February 2024 - 12:24 PM
Issue joining exterior wall material between floors. I'm most likely overlooking something simple. Thanks
Posted 01 February 2024 - 12:27 PM
Make sure the floor is in the correct place, then edit the wall and check COVER FLOOR
#3 Steve Gray
Steve Gray
  • 11 posts
Posted 01 February 2024 - 01:10 PM
Thanks Keith.  Check that earlier and 1st and end floor walls are properly aligned. COVER FLOOR checked in wall edit menu. Executed clean up as well - no change.
#4 Henry Buckner
Henry Buckner
  • 342 posts
Posted 01 February 2024 - 01:41 PM
Sometimes if you uncheck and recheck that button it fixes it.
#5 Mark Petri
  • 1,512 posts
Posted 01 February 2024 - 02:28 PM
If a majority of the segment of wall is not over a floor system it will sometimes misbehave as well. Check that and cut the wall into 2 if needed. Otherwise, grab your exterior wall finish and create a wall just out of that and adjust offsets and height and place accordingly if needed.
#6 Gary Wicklund
Gary Wicklund
  • 162 posts
  • LocationDuncan BC Canada
Posted 01 February 2024 - 07:34 PM
Check all your wall offsets, I recently had this happen and it was a wall offset was wrong.
use the profile feature to see if you have any goofy wall offsets or heights.
Looks like your missing the rim joist?
#7 Steve Gray
Steve Gray
  • 11 posts
Posted 02 February 2024 - 10:18 AM
Two story dwelling. In error placed ceiling joists on the 1st floor drawing.  First story ceiling joists are formed with th 2nd story floor joists of the 2nd floor. Corrected drawings and issue is resolved.  Thanks for all input.
Text from support response:
The second floor should have a floor system comprised of a ring joist, Joists, and subfloor. That serves as the ceiling structure for the first floor. The first floor should not have ceiling joists anywhere that there is a second floor above. The wall on the second floor then covers the floor system for the second floor.
