When i go to rooms, I'd like for the room label to give me just a name and not try to add the ceiling , floor , etc.
Is there a location to turn those off
Posted 28 February 2024 - 09:31 AM
Hi Fred,
You'll have to go into the system library and change the library type to "Rooms". From there, you can edit the defaults of what comes in when you place a room.
I'll try to include some screenshot examples of what you're looking for.
Hope that helps!
Posted 28 February 2024 - 10:07 AM
Posted 28 February 2024 - 12:14 PM
I'd go into windows explorer, and copy the ?:\Softplan 2024\Rooms\(Library of Choice - I have 2) directory and rename it Labels, and then turn off everything except labels as Colin noted above. That way you can use a Library to label and still have a library to enable finishes.
Posted 28 February 2024 - 07:05 PM
David, I might be mixed up, and haven't had time to explore info from you guys,
but I like to use ceiling mode to place the ceilings and then I go to interiors to place flooring, base, and wall covering, etc.
Seems the order I go, with how I put a plan together. When I do room names it tells me I'm adding a ceiling on top of a ceiling, and so on.
I might be looking at it wrong. But I would like to use "rooms" labels and maybe have the room size, I like to put the ceilings in and when I start
flowing into 3D I go to interiors and plug that stuff in, etc.
I'm pretty busy, building and then do drawings, and forget a lot of how Softplan works, a little memory loss.
Going to system options is sometimes like "go fishing"
