Roof layout lines
#1 Fred Russell
Fred Russell
  • 620 posts
Posted 05 March 2024 - 11:39 AM
I want to have a clean roof layout, seem that the gables and intersect draws a box.  Can't figure out how to get that box out of there
and that left valley doesn't want to show
  • Attached File  roof.pdf   40.82KB   56 downloads
#2 Steve Haarmann
Steve Haarmann
  • 645 posts
Posted 05 March 2024 - 12:09 PM
Instead of drawing 2 separate roofs you can trace around the exterior and change the front to a gable.
Auto roof should give you what you want also.
If you adjust the rear of the gable box towards the front and edit it to intersect you can also fix this.
When you edit it be sure that the intersect roof pitch is correct.
#3 Sam Morgan
  • 851 posts
Posted 05 March 2024 - 06:13 PM
Definitely what steve said...that's a simple enough roof to do in just one roof.
#4 Fred Russell
Fred Russell
  • 620 posts
Posted 05 March 2024 - 06:34 PM
Thanks, Steve 2 fixes.     pulling that box back I haven't tried, but that is good info. especially on more complicated roof.
I did do the Elevation  that Keith told me  of using that middle button on elevations, and it pops up a roof layout like an
elevation does and it can be "saved as" a softplan drawing and treated like an elevation, but is a roof layout that can be
changed because it is just lines.
Learned a lot of little tidbits on the forum today.
