Is there a better way to import a PDF as shapes in Review to not have it explode everything?
Recently I imported a lighting plan which had a lot of circles representing track lighting and the number of items on the drawing went to about 150000, each circle was exploded into about 450 different segments plus a polygon...lol
Even lines get exploded to multiple segments.
Is there a different format I should be using?
The lighting plan isn't a normal type of file I import, but even surveyor PDF's can get big also.
Btw DWG's do the same thing, rather than a 1 item circle I get a exploded multi segmented one.
