DWG text scale
#1 Gary Wicklund
Gary Wicklund
  • 162 posts
  • LocationDuncan BC Canada
Posted 28 March 2024 - 07:58 PM
Need help adjusting the text size of DWG I imported, the text is 3/8” high on the imported drawing, I need atleast 6”.
Max scale on plan set still doesn’t make it big enough.
I didn’t see a scale factor when importing, is there a setting somewhere for importing DWG’s
TIA
#2 Fred Dickson
Fred Dickson
  • 208 posts
Posted 29 March 2024 - 08:06 AM
Maybe a quick work around is use the adjust size in the edit menu.  You can scale it to the exact size you want.  New size/existing size will give you the ratio you need.
#3 Gary Wicklund
Gary Wicklund
  • 162 posts
Posted 29 March 2024 - 08:39 AM
Thanks Fred, that was it.
For some reason I thought the adjust size only worked for pdf’s
