Trim Lines
trim line box dashed line
7 replies to this topic
#1 Jay Johnson
Jay Johnson
  • 40 posts
Posted 28 April 2024 - 08:12 AM
I recently updated doors in our library to represent the trim profile I always took the time to change in the door settings.  Now the red dashed lines showing the trim are not displayed on the drawing.  I even selected a door from the stock openings that I have not changed and the red lines are not there.  Does anyone know where or how to fix this?
#2 Fred Russell
Fred Russell
  • 846 posts
Posted 28 April 2024 - 11:52 AM
Probably, it is that if you select         "Options"         "Visible items"  and at bottom on left, if "shows non-printable Items is not checked, then this could be the problem, so check box.
I see that the box for default or Custom trim in opening edited would also need to be checked
#3 Jay Johnson
Jay Johnson
  • 40 posts
Posted 28 April 2024 - 01:00 PM
Fred, thanks for the reply, I appreciate it.
1.  "Custom interior trim" is checked for interior door under "edit" on the doors.
2. Never thought to check the box you mentioned under "options" and "visible items" for "non-printable items".  That box was also checked.
Still does not show the trim boundary box.  Other thoughts?
#4 Fred Russell
Fred Russell
  • 846 posts
Posted 28 April 2024 - 01:29 PM
Maybe on edit opening, int. or ext trim ,   the custom trim is showing as None?
#5 Jay Johnson
Jay Johnson
  • 40 posts
Posted 29 April 2024 - 05:20 AM
Fred, the trim does not show none.  It's a head scratcher for sure.
#6 Fred Russell
Fred Russell
  • 846 posts
Posted 29 April 2024 - 08:38 AM
There used to be a place to turn the trim off or on, it did the same with the corner boards for Siding. check if the corner boards show a red line?
I couldn't find it I think  upgrades changed it
#7 Steve and Carla Farnam
  • 680 posts
Posted 29 April 2024 - 10:15 AM
Go To>Options>Visible Items> Disable or Enable Wall Interior Treatment and/or Wall Exterior Treatment
#8 Fred Russell
Fred Russell
  • 846 posts
Posted 30 April 2024 - 04:49 AM
Great. nice to know, that got snouk over there at some point
Also tagged with one or more of these keywords: trim, line, box, dashed line
