Setting floor to floor datums
floor to floor heights datums setting floor heights Cleanup
#1 MELINDA ROBERTS
MELINDA ROBERTS
  • 7 posts
Posted 29 January 2018 - 11:40 AM
I'm new to Softplan and am finding setting floor to floor datums frustrating. Is there a simpler way to adjust floor to floor heights other than changing wall heights? I would love to be able to pick the floor and set a datum height but can't find a way to do that. When I change all wall heights on a plan (which is so tedious) and then use Cleanup, I find that the floor above or below still hovers, unattached to the changed walls.
#2 Martin Livingston
  • 703 posts
Posted 29 January 2018 - 12:37 PM
You need to set a common reference point using the circle reference tool. Pick a point common to each drawing like an inside face of an exterior wall corner (watch out for cantilevers). Softplan will use this point as the vertical end of one floor and the vertical start of the next in the model.This only works with the circle reference. To speed up the setting of wall heights use the "select type" or "select group". If you hover over a DW/2X4/DW wall section, right click and "select type" it will highlight all of the DW/2X4/DW walls in the drawing which you can edit all at the same time. If you had chosen "select group" Softplan would have selected all of the walls in that drawing and you can edit them as a group.
  • MELINDA ROBERTS likes this
  • 5,301 posts
Posted 29 January 2018 - 01:50 PM
You need to learn all about the Circular Reference point. That will fix your issues.
Have a look at this post ... http://softplan.com/...f-house/?p=5596
Also tagged with one or more of these keywords: floor to floor heights, datums, setting floor heights, Cleanup
