Stairs mid-landing
#1 Andrew Morrison
Andrew Morrison
  • 16 posts
Posted 17 September 2021 - 01:11 PM
How do I change the height of a landing mid-stair? I adjusted the number and height of some of the risers, but the landing did not change height to match them.
Thank you,
AM
  • 5,299 posts
Posted 17 September 2021 - 03:49 PM
Did you adjust the whole stair, or did you explode it? Typically it's simpler to add a new stair and adjust the whole stair to suit rather than try and adjust the landing.
  • Andrew Morrison likes this
#3 Jay Preeshl
Jay Preeshl
  • 16 posts
Posted 19 September 2021 - 06:41 PM
offset the landing itself. landing won't move with stair edit.
#4 Andrew Morrison
Andrew Morrison
  • 16 posts
Posted 20 September 2021 - 06:58 AM
When I go to edit the landing itself, I don't see an option for offsetting. I can change the depth, which at least gets the floor finish up the right height.
I'm not sure how to adjust the whole stair, when I click on either run of steps or the landing, it edits just that part individually.
#5 Tim Kenyon
Tim Kenyon
  • 24 posts
Posted 20 September 2021 - 10:55 AM
I usually put a section line through the stairs and landing and then move the landing up or down to suit.  I draw the lower stair section first then the landing then the upper section.  Seems to work faster for me.
  • 5,299 posts
Posted 20 September 2021 - 05:26 PM
It will if it's adjusted as part of the whole stair.
if you have exploded the stair, you can't edit the whole. That's why i suggested you redraw the staircase. Have a look at this thread ...
http://softplan.com/...like-this-in-sp
