Any way to place the 3d render onto the actual site plan drawing?
3d site plan
#1 Thomas Parker
Thomas Parker
  • 51 posts
Posted 17 February 2015 - 10:11 AM
Is there any way to display the 3d rendering onto the actual site plan drawing (instead of grass)? I have a site with unique setback challenges and would like to display the renderings indicating the setback lines on the site. The 2d site plan will be fine, if it's too complicated!!!!!
Thanks for any help you may offer,and have a good day,
TOM
v2014
Tom Parker
TJP Designs and Const. LLC
v10 - v2020
  • 5,301 posts
Posted 17 February 2015 - 10:54 AM
If you draw the setback on the site plan, you can change the texture so that the setback area shows differently from the site texture (I think it may even be different as standard). You can still fit it to ground - although in my experience, fit to ground typically doesn't.
  • Thomas Parker likes this
#3 Chris Stewart
Chris Stewart
  • Banned
  • 238 posts
  • LocationTexas
Posted 17 February 2015 - 11:27 AM
Sure -you can overlay an image on any drawing -File/Import/Image
-Chris
#4 Thomas Parker
Thomas Parker
  • 51 posts
Posted 17 February 2015 - 11:45 AM
What a great solution Keih, and so simple - just clicked 'on' the display setting for 'Setback' in Materials and changed the color - Perfect!
Thanks for tip and quick reply!!!
Take care,
TOM
Tom Parker
v10 - v2020
#5 Thomas Parker
Thomas Parker
  • 51 posts
Posted 17 February 2015 - 12:08 PM
Hi Chris,
Thanks for the reply, but I'm sorry I don't understand how to overlay the image of my site plan onto the 3d rendering? I'm willing to try, but I can't seem to figure out where to get the image from and how it would fit in the right spot on the 3d site? Oh well, this is probably too advanced for me, HA HA
Thanks again for the reply,
TOM
Tom Parker
v10 - v2020
#6 Chris Stewart
Chris Stewart
  • Banned
  • 238 posts
  • LocationTexas
Posted 17 February 2015 - 12:13 PM
I guess I did not understand what you where wanting to show but it sounds like you found your solution.
-Chris
#7 randolph cohn
Posted 03 April 2015 - 10:01 AM
thomas,
i'm not sure i understand what your after
you ask:
"Is there any way to display the 3d rendering onto the actual site plan drawing (instead of grass)? I have a site with unique setback challenges and would like to display the renderings indicating the setback lines on the site. The 2d site plan will be fine, if it's too complicated!!!!!
Thanks for any help you may offer,and have a good day,"
randy answer:
the way i understand what your asking is if you can put the image of the site onto your site plan > if this is correct,
you can add an image (jpg, bmp, png) into your softplan / 3d / texture / bmp /site / (an existing folder or create a new folder in site or anyplace
in the texture folder of 3d )  and than / file / import /image onto your SPD drawing.  you can either use / edit / adjust size after importing
or use the / adjust command and adjust each size as needed.
if my assumptions of what your need are incorrect, please correct with what you actually want.
Also tagged with one or more of these keywords: 3d, site plan
