I am awaiting the moment that SoftPlan incorporates the ability to add profiles and 3D geometry to the roof surfaces to mimic standing seam and clay tile roofs since a simple texture (even with a bump map) isn't as realistic for the level of detail I need my renders to be for some client projects. I do own sketchup and I stumbled upon this plugin:
Instant Roof Nui | Vali Architects | Instant Scripts
YouTube Tutorial:
INSTANT ROOFS IN SKETCHUP with Instant Roof NUI (youtube.com)
The only downside is this is a $39 yearly subscription for this extension however it saves me the time from physically modeling roof profiles and tiles which would need to be applied to the roof manually. There are a ton of tutorials on how to add 3D geometry to roof planes in sketchup but this extension is such a time saver for the fast turnaround I need to produce accurate 3D Models for rendering.
I was wondering if anyone has had experience with this plugin or has seen any other extensions/methods they use to get 3D geometry onto roofs inside sketchup? The only other downside is that if I make changes to the model and re-export to sketchup, my roof settings applied with this extension may be deleted, unless I save the roof geometry that is generated as a component and reimport it once I have an updated model (assuming the roof line hasn't changed).
And yes, I have thought about using a row of profiled beams on a separate layer and adjusting them to fit to the top of roof however this seems like a time-consuming process but if anyone has had successful results with it, that would be another option I'm considering exploring as a current workaround that doesn't require separate modeling in sketchup. If I do use profiled beams for the 3D effect, the only thing would be how well a texture simulates the natural lapping of the clay tiles. I am sure it is possible but if more accurate results are achievable with this plugin, I guess it is worth the subscription for this niche feature to have for increasing the realism of these roof types in 3D.
