Wall Types, Default Wall List
wall types default wall list
1 reply to this topic
#1 Dave Pazyniak
Dave Pazyniak
  • 403 posts
Posted 13 August 2016 - 06:07 AM
Good Morning,
It appears if I add wall types to my system options, then use a different default wall list (like for a remodel project), any custom walls I created under the previous wall list is now gone.  Is there some way to add wall types to a list permanently, but use the different default wall lists for different projects?  Or maybe create one custom default wall list?
TIA,
Dave
Posted 13 August 2016 - 07:14 PM
No, you can't do that.
Choose ONE wall list and stick to it!
if you change to a default wall list, It reloads the default from Softplan's installation files, and as you found out you lose all customization.
You can however, return to the drawing you used it on, export the wall (or walls) that you are missing and then re-import them into the current wall list.
Also tagged with one or more of these keywords: wall types, default wall list
