2020 setup
setup
9 replies to this topic
#1 Danial Anderson
Danial Anderson
  • 57 posts
  • LocationMichigan
Posted 24 May 2019 - 04:20 PM
I have prior versions of softplan in my computer
softplan 2020 is asking if
yes, copy my soft plan configuration, projects, and custom symbols
no, do not copy my soft plan configuration, projects, and custom symbols.
The "no" is a pre selected choice, I really think I want to click yes, but I'm 2nd guessing myself, only because soft plan had the "no" preselected.
question, which one am I suppose to choose . I don't know the consequences?
Thank you for any advice
D.A.
#2 Gary McKeon
  • 560 posts
Posted 24 May 2019 - 05:13 PM
I would choose "yes".
Posted 24 May 2019 - 05:42 PM
I also would choose yes ... if you choose yes, you get 2020 configured as your previous versions. if you choose no, you get a straight out of the box configuration.
#4 Kevin Rabenaldt
Kevin Rabenaldt
  • 391 posts
  • LocationSan Antonio
Posted 25 May 2019 - 09:24 AM
I would choose no.  Take your 2018 project folder and make a backup using Windows.  I use something like SP2018ProjectBackup.  Now do an archive in SP 2018 on everything except projects.  Load SP 2020.  Then use the archive to bring in everything except your old projects.  Then in the new project folder copy and paste those projects you want to reside in your SP 2020 or you may want they all.  This way you have a "clean" copy of all your old projects.  Being able to get a clean copy has saved me on a number of occasions when I have upgrade SP.  Just the way I do it for many upgrades now.  When you open an old project in the new version, it will convert your old version to new version.
#5 Steve and Carla Farnam
  • 657 posts
Posted 25 May 2019 - 11:06 AM
Ditto Kevin's Upgrade steps
Posted 25 May 2019 - 11:51 AM
As far as I'm aware, the steps you are doing is just the same as choosing YES. You can still edit the project folder to only use new projects, but choosing yes saves all the intermediate steps. Why the roundabout route? Choosing no, just gives you an out of the box configuration. If all you then do is restore everything you archived, you may as well have chosen yes. I may be wrong , but doesn't choosing yes, just move everything you had before into the new version just the same as restoring your archive does.
Would someone from Softplan like to clarify the differences/benefits either way?
#7 Harald Schwegel
Harald Schwegel
  • 74 posts
Posted 28 May 2019 - 09:48 AM
Keith is correct in all his points.  Selecting Yes does automatically what Kevin is doing manually in his post.
As to why the selection defaults to No - it is simply erring on the side of caution.  Undoing the result is next to impossible without uninstalling, deleting and reinstalling so we want users to be sure this is what they want to do. There can be several factors to consider including that the correct source was found, that it hasn't previously been done it, etc.
  • Danial Anderson and Brent Hyndman like this
#8 Edward Shannon
Edward Shannon
  • 151 posts
  • LocationDes Moines, Iowa
Posted 13 June 2019 - 03:49 PM
I am trying to do this but did not get the prompt to migrate files.   Kevin, you refer to "Use the archive"  Where is this located?
#9 Gary McKeon
  • 560 posts
Posted 13 June 2019 - 11:28 PM
System Options 2nd from the top I believe.
#10 Edward Shannon
Edward Shannon
  • 151 posts
Posted 14 June 2019 - 08:09 AM
Thanks, I ended up uninstalling and the reinstalling the program.
Also tagged with one or more of these keywords: setup
