In plan sets you may set "Building Options" "Use Custom Visibility" (see attachment) for plans and never have to worry about the model again (for plans).
Plans are ready to publish at all times.
For annotated views and 3D views we have to RESET set the building options in the model before publishing each version of options.
You better be real careful reviewing you published work for small differences between option versions.
To me that can lead to publishing the wrong version, it's confusing, time consuming,
inconsistent workflow, and not to mention aggravating
SP be consistent. Make all plans set options the same.
P.S.
Keith Almond "The building options should be set BEFORE the drawings get to the plan set."
You may change the building options anytime during the drawing process (as it should be).
You do have to RESET set the building options in the model before publishing each version of options.
SoftPlan+ 2018
OS - Windows 10.0 Pro 64 Bit
CPU - AMD FX-8350 8-Core 4.01 GHz
MB - ASUS SABERTOOTH 990FX R2.0
RAM - 16GB DDR3 1866 MHZ
Graphics - ASUS ROG Strix Radeon RX 570 O4G Gaming OC Edition
3Dconnexion Wireless 3D SpaceMouse
3Dconnexion CadMouse
Corsair K95 RGB Cherry MX Brown Keyboard
