Board and Batten Profile in Gable Ends
elevations board and batten textures profile
#1 Josh Huskins
Josh Huskins
  • 19 posts
Posted 04 August 2023 - 09:46 AM
There's probably an easy fix for this. Instead of me taking forever to figure it out i think you all could come up with something fairly quickly. See the image attached. The entire lake side of the home should be board and batten. I just started using profiles to show the definition of the vertical strips. I adjusted the walls to reflect this but the gable ends will not show the b&b strips.
FYI, the wall definition siding was changed to board and batten with the profile, the gable ends are also board and batten.
#2 Mark Petri
  • 1,976 posts
Posted 04 August 2023 - 10:06 AM
You can click on the gable roof edge and the "gable siding" section and check the box by profile. Then assign the same profile for the gable ends as you are using in your wall definition.
  • Thomas Davis, John Jones and David Zawadzki like this
#3 Josh Huskins
Josh Huskins
  • 19 posts
Posted 04 August 2023 - 11:58 AM
Perfect, Thank you!
#4 Bill Wimberley
Bill Wimberley
  • 654 posts
  • LocationSan Angelo, TX
Posted 04 August 2023 - 12:03 PM
You can also use textures rather than profiles.
  • Thomas Davis, Steven Wohlgemuth and Tracy Guest like this
Also tagged with one or more of these keywords: elevations, board and batten, textures, profile
