Accent Truss Overhang Tail
16 replies to this topic
#1 Tom McConnell
Tom McConnell
  • 277 posts
  • LocationSaint Augustine, Florida
Posted 16 August 2019 - 07:29 AM
Just want a triangle.
How do I remove the Accent Truss overhang tail?
  • Attached File  SP07.jpg   110.38KB   2 downloads
SoftPlan+ 2021
SP since 2012, AutoCAD since 1994
OS - Windows 10.0 Pro 64 Bit
CPU - AMD RYZEN 9 3900X 12-CORE
MB - ASUS ROG Strix X570-E
RAM - CORSAIR VENGEANCE RGB PRO 32GB DDR4
Graphics - ASUS ROG Strix Radeon RX 570 O4G Gaming OC Edition
3 - ASUS MX279H 27 Inch LED Monitors
3Dconnexion CadMouse
Corsair K95 RGB Cherry MX Brown Keyboard
#2 Jon Davis
Jon Davis
  • 541 posts
Posted 19 August 2019 - 06:42 AM
I tried playing with all the different styles  last week myself, and none of them had that configuration.
I ended up creating my own 3D symbol.
#3 Mark Petri
Posted 19 August 2019 - 07:52 AM
I believe it would work well if we were able to control the width as well as height of the accent truss. Or, if there was a tail setting to adjust how much top chord tail there is. SP - please give us more options with the accent truss settings!
  • Allen McDonnell likes this
#4 Tim Stockton
Tim Stockton
  • 313 posts
  • LocationWichita, KS
Posted 19 August 2019 - 02:15 PM
Tom - I've noticed the same thing - I don't think there is an option to allow us to remove that.
Posted 22 August 2019 - 07:32 PM
Since the truss follows the roof pitch changing either the width or the height does the same thing.
I agree about the tails ... personally, I'd prefer them NOT to be there.
I'd also like to be able to add a decorative "cap" feature below the king post.
It would also be nice to be able to add a curve to the bottom chord.
This is being picky, but I'd also like the centre of the webs to fit to the junction of the king post and the bottom chord, instead of the top edge of the web. It just looks wrong somehow.
I added an accent truss to an open porch this afternoon ... However, with the extended tails, it didn't work at all, as the tails fell below the fascia, because the bottom chord functions as a collar tie at eaves level.
90% of all the feature trusses I've seen DON'T have extended tails.
AND BY FAR my biggest gripe, please ADD configurable DEFAULT settings for the accent trusses to the material options. I have to change almost EVERY setting EVERY TIME. 3½" chords and webs really don't work for accent trusses ... typically they are at least 6" material.
  • Warren Ducote, Rick Kingsbury, Tim Booth and 1 other like this
#6 Mark Petri
Posted 23 August 2019 - 09:31 AM
If you notice, Keith, we only have control of the height. If we could control both, it would be possible to set the rafter and bottom chord to be where they meet at their lower/outer corners. Right now, when adjusting height the width automatically adjusts to include enough for a tail. I found, as you may have, this is the way it is set up except when you make the truss tall enough that the width exceeds the roof gable by some amount. Then, it clips the tail. But it looks horrible. I suppose one could use a small roof gable and change settings to only extract the truss possibly?? Maybe not. See attached
#7 Keith Almond
Posted 23 August 2019 - 12:01 PM
I hadn't noticed that Mark. I've never tried dropping it down that low. I was under the impression that the tails were fixed.
#8 Dennis Asher
Dennis Asher
  • 203 posts
  • LocationWillow Springs, Missouri
Posted 19 August 2020 - 07:55 AM
For some reason I can't edit the width of the accent truss
#9 Jon Davis
Jon Davis
  • 541 posts
Posted 19 August 2020 - 07:59 AM
It should be in there, I think it's listed as length though...
#10 Dennis Asher
Dennis Asher
  • 203 posts
Posted 19 August 2020 - 08:27 AM
Your're right, it is called length. It's grayed out and won't take any input.
#11 David Zawadzki
  • 663 posts
Posted 19 August 2020 - 06:18 PM
Have you tried a ceiling truss? I think that is what it is called...
#12 Jon Davis
Jon Davis
  • 541 posts
Posted 20 August 2020 - 06:39 AM
Ok I opened up a model and put one in... the length is a factor of the height. You have to put in the height to adjust the size. The "width" is what they are considering the depth of the lumber. It's set to 1.5 so you can change it to 3.5 for a 4x4 timber, but you really will only see a difference in certain 3D shots...
So You can only adjust the height, the length will adjust itself based on the slope of the roof.
#13 Dennis Asher
Dennis Asher
  • 203 posts
Posted 20 August 2020 - 09:31 AM
I had tried that but at a certain point is quits getting wider and instead gets taller with "heels".
Attached File  Accent Truss.pdf   195.75KB   38 downloads
#14 Mark Petri
Posted 20 August 2020 - 09:36 AM
I typically draw the final timber or log trusses in SketchUp. I also have a plugin in SketchUp that will often work to draw the timber or log truss the way I want and then I just import it. For initial look, sometimes I'll use an accent truss in SP, but final drawings need better control, so I just make it in SketchUp and import. Then I can also grab any view I want for details.
  • Jon Davis likes this
#15 Dennis Asher
Dennis Asher
  • 203 posts
Posted 20 August 2020 - 10:06 AM
I usually draw the truss with solids and them import via the wizard.  Fortunately, I am swamped and I had hoped the accent truss would be a quick and easy way to show for preliminary designs.  Also I may be getting lazy in my old age...lol!
#16 Brendan Smythe
Brendan Smythe
  • 86 posts
Posted 27 August 2020 - 01:15 PM
definitely room for improvement on these accent trusses. I was excited when they announced this feature, but I never use it. Mostly because of those tails...
  • Bernard Toews and Rick Kingsbury like this
#17 Philip Frank
Philip Frank
  • 560 posts
  • LocationMaine, USA
Posted 28 August 2020 - 03:52 AM
Are you aware that you can make the top chord disappear (essentially eliminating the tails) by simply removing  the checkmark in the "Top Chord" box?
  • John Jones, Ben Ginther, Steve Haarmann and 7 others like this
Also tagged with one or more of these keywords: Accent Truss, Overhang
