Im quite new to Soft plan and its capabilities. I drew my rough sketch of a plan with a 5.5 inch partion making sure wall joints ran together properly. When i go to auto dimension it just bloops and doesnt do anthing, not sure how to get my exterior dimensions. Any Help would be appreciated.
Posted 15 June 2016 - 07:31 AM
Auto dimension or Auto Dimension Side works based on load bearing walls or exterior walls and the interior walls that connect with exterior walls if set in the System or Drawing Options. If you edit the definition of your 5.5 inch partition and set the studs to bearing, then the Auto Dimension will work.
Posted 15 June 2016 - 07:43 AM
Auto dimensions work with exterior walls. Try switching them to an exterior and it should work
Reply to this topic
Also tagged with one or more of these keywords: Dimension, Autodimension
SoftPlan version 2020 →
"Esc" key does not cancel the dimension commandStarted by Tom McConnell , 25 Sep 2019 Esc, key, cancel, dimension |
Dimension circle radius and diameter ?Started by Tom McConnell , 18 Jul 2019 Dimension, circle, radius and 1 more... |
SoftPlan 2018 →
Dimensioning woesStarted by Rick Kingsbury , 31 Oct 2018 dimension |
how modify length of just one side of a triangle?Started by Softplan Newbie , 29 Mar 2018 dimension, polygon, shapes and 2 more... |
SoftPlan 2016 →
How to set a specific dimension location so it staysStarted by Verlin Klassen , 13 Oct 2016 dimension |
