Custom Garage Door Opening: Tutorial
#1
Posted 05 April 2015 - 03:32 PM
- Jim Crook, Thomas Davis, Jeff Hamilton and 4 others like this
Posted 06 April 2015 - 08:54 AM
You're very welcome Matt, hope more people get something out of it.
Posted 24 July 2015 - 11:17 AM
Thank you and nice work on the tutorial Keith. I did this but with an interior door. Now for the questions.
- When looking at the door in 3D there are no edges for the perimeter of the door. How do I correct that?
- The wood grain texture on the SP door to the left runs in the same direction as the rails & stiles. 1) How do I get the wood grain texture of the SP door on mine and 2) how do I get it to run in the same directions for the rails & stiles.
Posted 24 July 2015 - 12:20 PM
Ahh ...
Now you've noticed the flaw in the plan ....
If there's a way for the door to have edges, I haven't figured it out yet. Maybe someone smarter than me has an answer.
and the second question ....
Softplan's 3D doors were not created in Softplan. They are specifically designed 3D models. However, you can edit the textures for certain parts of the door in the surface editor in the 3D window. Experiment ...
You can import 3D models from SKETCHUP's 3D WAREHOUSE using the WIZARD in the CONFIGURE LIBRARY menu.
Posted 29 July 2015 - 06:25 AM
Do the elevation the same way, but when you create the opening, under SYSTEM LIBRARY > CONFIGURE LIBRARY > OPENINGS when you create the opening, go to EDIT INDIVIDUAL COMPONENT. Change SECTIONS to 2 and OPERATE to LR
Posted 29 July 2015 - 08:40 PM
I'll have to say Keith at some point I'm gonna stump you yet! Now on to another one. I created a custom garage door with a model I spent all day on. When saving it as an opening in SP, I did not get the overhead dashed line like you have in plan view and I do not know how to get rid of the door knobs in the configure menu. On a side note, when I create an opening, where is it that I need to change the file name so that the drawing shows all uppercase?
Thank you,
Jerry
Posted 30 July 2015 - 06:27 AM
Of course you'll stump me, Softplan does it every day!
If you didn't get the dotted line for an overhead door, then you missed a step ---- On the Component Tab, change Operate to "U" ---- To get rid of the door knobs. EDIT OPENING - go to the MISCELLANEOUS Tab and uncheck the Bottom Hardware and Top Hardware checkboxes. Although, they will probably automatically be removed when you change the operation to "U".
I think to make it show in UPPERCASE the actual symbol has to be named in Uppercase. Although I don't use uppercase generally. I only use in to emphasize.
I assume that door symbol was created in Sketchup and imported ...! I'm trying to find a way to show hinges within Softplan, but at the moment am drawing a blank.
Posted 30 July 2015 - 06:37 AM
Duplicate post ... DELETED
Posted 30 July 2015 - 07:25 AM
1) I do have operate set to U and I am still not getting it. Is it possible that since I used a Sketchup model that that is why I am not getting it?
2) So you have to get rid of the door hardware after the fact. There is no way to keep it from happening beforehand.
Thank you,
Jerry
Posted 30 July 2015 - 09:00 AM
Not sure how you built it James, I'd do elevation and plans separately, and then link to a Sketchup model AFTER everything is built. Haven't tried it, so don't actually know at what stage you link to that model, but I would not have expected being linked to a sketchup model to make any difference.
As I said earlier, typically if it doesn't need hardware (like a Upward opening door), I don't think it will add it, so it's not a question of keeping it from happening. Somehow, the fact that it's not showing the dotted upward opening, and is showing hardware are linked.
Posted 30 July 2015 - 11:03 PM
I found the issue Keith.
Now under Type Choose "Garage" and select the library and symbol you created earlier. And press OK
I did not choose "Garage" when creating the Opening, I chose "Door".
After having tried creating this door several different times and then having to go through all of the "garage" directories that I created for myself for the symbol and the elevation opening and the opening I was thinking that you were just referring to a directory. It added the overhead dashed line and removed the door knob both.
Thank s for the help!
Jerry
#14
Posted 16 August 2015 - 08:02 PM
Is there a way to control the width of the frame when using Detail -> Opening Shapes to create a new door? I thought it would have been the frame thickness under System Library ->Material Dimensions -> Opening Options -> Component Sizes but after changing it it still had no effect.
Thank you,
Jerry
#15
Posted 17 August 2015 - 06:40 AM
If you change it in the system options, then it will only change for the next new drawing that you open. Try DRAWING OPTIONS > MATERIAL DIMENSIONS > OPENING OPTIONS > FRAME THICKNESS, although this is going to change every frame in your drawing.
Posted 17 August 2015 - 07:54 AM
#19
Posted 08 September 2017 - 08:02 AM
On the craftsman style garage door posted above, how are you drawing the decorative hinges? Is that something provided by SoftPlan or are you drawing lines on the elevation and making a custom elevation?
The model was created in Sketchup.
You can't show the hinges and handles in Softplan by any simple means ... if you draw them as lines you will end up with a single 3D outline of a hinge, the same colour as the door. The simplest method is to create a single decorative hinge as a separate symbol and position it/them to suit. Same with the decorative handles.
Also tagged with one or more of these keywords: garage door, tutorial, opening
Openings and wall wrapsStarted by Dennis Swihart , 23 Sep 2023 wall wrap, header, opening |
Window OffsetStarted by Wesley Penner , 20 Oct 2022 Opening, offset |
SoftPlan 2018 →
Custom "Arch" OpeningsStarted by Dustin Hollingshead , 19 Jul 2018 Opening, Arch, Special |
Guest Area →
Guest Questions →
Can't open existing projectStarted by Philip Bennington , 20 Jun 2018 opening, existing project |
SoftPlan 2018 →
Opening Multiple DrawingsStarted by Keith Almond , 25 May 2018 opening, multiple, drawings and 1 more... |
