Stamps
stamps
#1 Jason Fischer
Jason Fischer
  • 16 posts
  • LocationGranger, Indiana
Posted 23 February 2016 - 12:53 PM
Is there a way to use multiple stamps in the same line (city, state & zip)?
#2 D M
D M
  • 402 posts
  • Location..
Posted 23 February 2016 - 01:28 PM
Detail Note .. Stamps .. click Stamp (select the stamp) ..
.. click Stamp again, .. keep adding ‘stamps’ to the note
Problem may arise when text string of first stamp overwrites into second stamp, .. maybe play with the spacing, font size etc.
I don’t use stamps much, .. so I’m not familiar with how they may want to interact.
Posted 23 February 2016 - 01:29 PM
No, I asked Tech support. The best they could come up with was:
"No, each information stamp needs to be on a separate line in the note or as a separate note on the drawing. if you use 2 notes you could set the first one to be right justified and then second one to be left justified so that they extend out from a specific location."
You could put multiple notes next to each other, but unless the project info is exactly the same length in each case, they will look a mess.
#4 D M
D M
  • 402 posts
  • Location..
Posted 23 February 2016 - 01:30 PM
I stand corrected
Posted 23 February 2016 - 01:34 PM
Cross posted ....
#6 Jason Fischer
Jason Fischer
  • 16 posts
Posted 23 February 2016 - 01:44 PM
Thanks - I had tried putting them all in a line but it doesn't pull the info.  I ended up doing the separate line, I just don't like the look.  I'll wait and hold out to a future addition!
Also tagged with one or more of these keywords: stamps
