Help on Roof
roof
16 replies to this topic
#1 Adrian Manalese
Adrian Manalese
  • 4 posts
Posted 08 June 2017 - 08:48 AM
Hello,
I am trying to achieve the roof on the right in red circle which has 3 panels. Please help.
#2 Jason Bishop
Jason Bishop
  • 295 posts
Posted 08 June 2017 - 08:54 AM
Try 'roof on bay'.
Posted 08 June 2017 - 09:26 AM
AUTO-ROOF should automatically create it!
#4 Adrian Manalese
Adrian Manalese
  • 4 posts
Posted 08 June 2017 - 12:00 PM
Roof on Bay did the trick. I have to clean it though.
Did I do it right?
Thank you.
Posted 08 June 2017 - 12:33 PM
Make sure the roof pitch in the options is the same as the roof on the rest of the house,
You could also use the INSERT POLYGON EDGE command and trace round the bay with it.
EDIT ...
Neither of those options worked properly, but there again the roof on bay didn't either.
#6 Adrian Manalese
Adrian Manalese
  • 4 posts
Posted 08 June 2017 - 02:36 PM
Here is my floor plan. I don't know how to render the roof correctly. Can you guys help please. I always have trouble working on that 3 panel roof.
#7 Fred Russell
Fred Russell
  • 620 posts
Posted 09 June 2017 - 04:45 PM
I think I have this,     Make sure the wall with front door and the right wall are the same distance in front, check that the 2 ea 45 degree walls are the same length, if not then the walls aren't right to the front.
Then trace a roof and go straight pass the 45 bumpout to the right wall, and complete the trace so it draws the roof except for the bumpout. Then I guess change the front wall to a gable.
It can be done other ways, but I adjust the front gable roof and get it out of the way.
Then use( "ADD ROOF")  by left clicking on the 3 bumpout walls, then right clicking in the middle of the 3 bumpout walls, if done right this will add  the bumpout roof.
Then edit the Gable roof edge and set the overhang to whatever you use I use 18" usually.
THen I guess you need to change the overhang on the bumpout to match the right overhang, not sure on that?
I think I have attached a picture of the result in roof mode
Don't think my picture made it
#8 Fred Russell
Fred Russell
  • 620 posts
Posted 09 June 2017 - 04:48 PM
picture?
think I got the picture
#9 Fred Russell
Fred Russell
  • 620 posts
Posted 09 June 2017 - 05:05 PM
little eyebrow roof over front door I believe you can trace it, maybe , and do some adjusting to get it right.
or I think "add shed roof" could work with some adjusting
#10 Tom Rogers
Posted 09 June 2017 - 05:17 PM
The roof is pretty easy to duplicate but the right front corner looks to be the problem.  I did traced the house and garage.  Then added wall for the bay.  Adjust to gables and such.  Use hip return to get the eyebrow over door.  Just cant figure out the clean up on the soffits.  I almost think that you need to have the back on just a little bit pulled forward from the house (so it doesnt hit at a 45 degree but turns back at 90 degrees).  Think an inch or so would do it.
#11 Fred Russell
Fred Russell
  • 620 posts
Posted 09 June 2017 - 05:20 PM
not sure I got It am in the middle of a drawing so I stopped to send a 3d
think this works
#12 Fred Russell
Fred Russell
  • 620 posts
Posted 09 June 2017 - 08:40 PM
maybe need the floor plan on that first post the first picture, the bumpout maybe needs to come out further?
especially if the bumpout roof needs to be at a 5/12 and peak up to the main roof
#13 Don Gibbons
Don Gibbons
  • 375 posts
Posted 10 June 2017 - 07:05 AM
From my experience, this type of roof has 5 roof planes but it only references 3 walls. SoftPlan adds a reference point for each wall, so there are two roof planes that don't have a reference point. The two roof planes that don't have rereference points form the horizontal ridge and and taper down to a point at the gutter. These two planes usually have the same pitch as the rest of the roof when it is built, however there's no way to control their pitch except through 'hit and miss' by changing the pitch (lowering it) in the Roof Options and then using the 'Roof on Bay' command.
#14 randolph cohn
Posted 10 June 2017 - 12:36 PM
fun with roofs
not saying you'd want to do this but i usually will try an "auto roof"  just
to see what happens.  might get a few alternate design ideas from it
to show your client.
don't tell them it took about 1 second.
#15 Fred Russell
Fred Russell
  • 620 posts
Posted 10 June 2017 - 02:19 PM
I think you would have to do the bump out like this to make all 5/12 take that look, note floor plan
  • Adrian Manalese likes this
#16 Adrian Manalese
Adrian Manalese
  • 4 posts
Posted 12 June 2017 - 03:08 PM
Thanks to all your input guys. I am very happy with your inputs and all I can say is "THANK YOU!" I have submitted the plans and will wait for client's thoughts. I was able to look in to Fred Russel's instruction.
bravo!!!
#17 Keith Almond
Posted 12 June 2017 - 06:56 PM
You may also be able to construct the roof if you use the original plan layout, but make the front gable a dutch gable.
Adjust the depth of the gable to suit.
Also tagged with one or more of these keywords: roof
