How high is my structure?
height
#1 Wouter van Tiel
Wouter van Tiel
  • 22 posts
  • LocationColorado
Posted 04 August 2018 - 06:27 AM
How do i dimension the height of the building?
I searched high and low to find a dimension tool to work on an elevation to show overall height (height restrictions exist in all our sub-divisions) but I can't find one, not in cross sections either. Could not find anything in help files. I must have missed something with my old eyes.
Thanks for your help.
#2 Steve and Carla Farnam
  • 656 posts
Posted 04 August 2018 - 06:45 AM
If you have generated your 2D elevation you can use the Set Distance Between tool under the Dimension Tab.
In 3D you can use the Distance tool under the Dimension Tab.
I always explode the 2D elevations to be able to reference the drawing as individual lines.
To show the dimension you can add extensions and dimensions.  Attached example
#3 Wouter van Tiel
Wouter van Tiel
  • 22 posts
  • LocationColorado
Posted 04 August 2018 - 06:58 AM
Thank you, I did find that after i wrote this but it won't show the dimensions for the architectural design review on the printed plans. Anyway to accomplish that?
#4 Steve and Carla Farnam
  • 656 posts
Posted 04 August 2018 - 07:00 AM
Check above post
#5 Yvon Gonthier
Posted 04 August 2018 - 07:01 AM
In 2D, you can use a line with snap activated to connect the line to the peak of the house. Then you can dimension from that line to the grade.
#6 Wouter van Tiel
Wouter van Tiel
  • 22 posts
  • LocationColorado
Posted 04 August 2018 - 07:28 AM
OK, thanks. The height must be done in the final elevation drawing as an exploded version. May be it could be made available to be done in the elevation tab while doing the concept drawing so we can adjust the roof pitch to match to highest we can design and build in a sub-division.
Also tagged with one or more of these keywords: height
