Text Settings
text width factor font
#1 A.J. Oranchuk
A.J. Oranchuk
  • 1 posts
Posted 09 December 2018 - 09:01 PM
Hello,
I am a new user to SoftPlan, and like the software so far. I do have a few questions that I can't seem to find answers to anywhere (this is also after a few hours of perusing the system settings and trying out different options).
1) Is there a system setting that allows me to choose a "width factor" for my fonts? I have a preference for using RomanS as my font, but I would like to set the width factor to 0.7 or 70% (it just fits better on the drawings and is still legible).
2) Am I able to change the default location where the leader attaches to the text for Pointer Text? The default is the top line of the text, but I would like it moved to the centre of the text by default.
3) Can I have the text change justification automatically when I reverse a drawing? Currently, if the justification is set to "Left" and I reverse the drawing, the justification stays "Left" after the reverse, but I would like it to change to "Right" when I reverse.
If there are already answers to these questions I apologize, I just can't seem to find the answers no matter what search parameters I set. I really appreciate any help anyone can give me.
My SoftPlan version is 2018.
Version: SoftPlan 2018
#2 Dennis Hilborn
Dennis Hilborn
  • 816 posts
  • LocationDFW Texas
Posted 10 December 2018 - 05:25 PM
1.  I haven't found a way to do width modifications to text, but that would be a great feature.  I too prefer narrowed text and 70% is about right.
If you also use another version of cad,  you could set the text the way you like it and create a drawing that is just one occurrence of each letter.  Then print that as a pdf.  There is a website that you up load the pdf and they will return you a text set that you can then use in SP.  That is what I did to get my favorite font that I used in Autocad to work in SP.
#3 Paul James
Paul James
  • 251 posts
Posted 11 December 2018 - 01:04 AM
Hey Dennis, which font is that- that you converted?
  • 5,625 posts
Posted 11 December 2018 - 11:07 AM
... I have a preference for using RomanS as my font, but I would like to set the width factor to 0.7 or 70% (it just fits better on the drawings and is still legible) ...
Since you can't actually do that with Softplan, consider using a standard windows font ... in this case something like CALIBRI LIGHT ... which will give very close to the same look.
  • 5,625 posts
Posted 11 December 2018 - 11:13 AM
The simple answers to your questions are NO, NO and NO, although there are workarounds for the first two.
As I said above you can use a similar windows font for item one.
For item 2 you can use an arrow instead of a pointer. I've never actually used a pointer for that very reason. I find the arrows (especially segmented or spline arrows) are much more flexible.
#6 Yvon Gonthier
Posted 11 December 2018 - 12:24 PM
Spline pointers are sometime interesting but a mess when you reverse a plan
Also tagged with one or more of these keywords: text, width factor, font
