Questions to softplan:
1. Board size 6000 mm.
What to do if the length of the walls and block more than 6000 mm?
2. How to act, if the length of the beams more than 6000 mm?
How to make building beams?
3. How to act, if the length of the Rafter feet more than 6000 mm?
How to make an artificial Rafter
4. How to act, if the length of the beam (truss fastening) of more than 6000 mm?
How to make an artificial bolt?
5. We need sites designs with dimensions. If the reality is changing the thickness (or kind) of the material, you must change the node. How do we do it?
6. how to automatically add a crossing of the floor beams with suspensions and the lack of suspensions?
7. is it possible to replace the hot keys on the standard of "Windows"? If Yes, how?
8. is it possible to insert into the body wall diagonal beam "automaton", as put by the bar?
9. Roof beams. How do we change the direction of the beams with a complex configuration of beams?
10. A beam ceiling. When we draw a ladder that is automatically increased. Why? When we draw the holes in the beams overlap to a specified boundary strengthening does not automatically drawn. Why?
11. is there an automatic layout of the roof roofing material "from stock" (multiple dimension lines)?
12. The dimension line. Not always correctly placed and tied. Need to be able to adjust. Where to look?
13. On the scan averaging walls (wall unit) are dimensions. How to change them? How to change the binding? How to add a new binding?
14. There was a difficulty with a drawing of two objects with different binding height wall (garage and the House. Difference in elevation 600 mm). How it is addressed?
15. How to make a video walk through the House.
16. There is a plugin that allows you to draw the axis. What we need to do this.
17. How to get the plugin to render to make photorealistic objects.
18. How to translate to Russian language program?
QUESTIONS 2014.3.4
Started by
Evgeny Krysin
, May 08 2015 04:49 AM
2014.3.4 russian Russian language plugin to render walk through the House hot keys
No replies to this topic
#1
Posted 08 May 2015 - 04:49 AM
Also tagged with one or more of these keywords: 2014.3.4, russian, Russian language, plugin to render, walk through the House, hot keys
SoftPlan →
SoftPlan 2014 →
QUESTIONS 2014.3.4Started by Evgeny Krysin , 08 May 2015 ![]() |
