PDF line thickness output
21 replies to this topic
#1 Dean Downey
Dean Downey
  • 40 posts
Posted 26 November 2021 - 03:22 PM
Hello,
Can't seem to get my PDF line thickness smaller than the 0.10 thickness.
I have in the past had my paint lines set to .05 and gray as opposed to black. Version 2014 is ok but 2022 seems to have trouble.
The shade output is good but the line thickness is still 0.10
Tried pretty much everything!
Dean Downey
dmdhomeplans.com
#2 Jon Davis
Jon Davis
  • 543 posts
Posted 29 November 2021 - 07:54 AM
Even if you change it to .05? You may have to override it in the layer properties. There are boxes for "use items linetype/color/etc..." so you may have to try that
#3 Dean Downey
Dean Downey
  • 40 posts
Posted 29 November 2021 - 11:47 AM
Appreciate the insight! Still no luck. Are you using 2022?
Even the sample drawings provided by softplan still show .10 line thickness when I make a PDF. Everything set to .05 in the pen thickness settings.
Cheers,
Dean
Dean Downey
dmdhomeplans.com
#4 Dean Downey
Dean Downey
  • 40 posts
Posted 29 November 2021 - 07:48 PM
Has anyone else had this issue? Seems like version 2022 pdf is broken! Can't go lower than the 0.10 line thickness.
Dean Downey
dmdhomeplans.com
#5 Sean Tobin
Sean Tobin
  • 48 posts
  • LocationRaleigh North Carolina, USA
Posted 30 November 2021 - 04:45 PM
Dean - I've been having a lot of issues with the lineweghts - both in terms of the viewing and the plotting.  It seems hit or miss to me at times.
#6 Dean Downey
Dean Downey
  • 40 posts
Posted 01 December 2021 - 04:35 PM
Yes thanks. I have passed it along to Tech Support and they agree with the problem.
Hopefully will rectify in the next patch.
THX
Dean Downey
dmdhomeplans.com
#7 Joseph Smith
  • 853 posts
Posted 02 December 2021 - 09:06 AM
Agree with Dean unable to achieve .05.  None of my work uses smaller then .10 so never explored this issue.
#8 Dean Downey
Dean Downey
  • 40 posts
Posted 02 December 2021 - 12:10 PM
2014 line thickness.jpg 2022 sample line thickness.jpg Thanks Joseph. Here is a sample from version 2014 (.05 thickness) and 2022 (.05 thickness but shown as .10)
Dean Downey
dmdhomeplans.com
#9 Jon Davis
Jon Davis
  • 543 posts
Posted 02 December 2021 - 12:45 PM
That's interesting. Are you referring to the paint hatches in these photos? I use .05 for mine and haven't noticed a difference. But I haven't really looked that closely either.
#10 Dean Downey
Dean Downey
  • 40 posts
Posted 02 December 2021 - 07:49 PM
Yes, if you look at the "shake" paint in 2014 its .05 and in 2022 its .10 even though it's set to .05
The first one is 2014 version and second is 2022
Dean Downey
dmdhomeplans.com
#11 Steve Haarmann
Steve Haarmann
  • 749 posts
Posted 03 December 2021 - 01:28 PM
In the meantime you can change the pen for paint to a medium gray color at .10
#12 Jon Davis
Jon Davis
  • 543 posts
Posted 06 December 2021 - 09:47 AM
I've got some brick and siding set at .05 and light grey, and they print the same in 2022 as they have in previous versions. Try changing the color??
My settings are, under pen setup, #15 is set to grey and .05.
I put all paint patterns (brick, siding, etc) on #15 (right click & edit, set it appropriately) and make sure that in my layers box, that "use items color" is checked for the paint layer.
  • Sean Tobin likes this
#13 Sean Tobin
Sean Tobin
  • 48 posts
Posted 06 December 2021 - 10:15 AM
I've been trying different combinations, and I've gotten SOME variation now.  But I really need to dig down into some of the settings - it does not seem like system settings are changing the printing - even on a new project once I create it.
Jon Davis, I'm going to try your specific setting on one project and see what I get.
  • Jon Davis likes this
#14 Dean Downey
Dean Downey
  • 40 posts
Posted 06 December 2021 - 05:54 PM
Yes the color can be changed but I can't get the line thickness below .10
I have not heard back from tech support!
Dean Downey
dmdhomeplans.com
#15 Joseph Smith
  • 853 posts
Posted 07 December 2021 - 12:51 PM
.05 doesn't even show on drafting standards charts for fine line thickness so doubtful you'll raise software interest.
I just tried V2020 and still not able to achieve .05mm, nothing is broke Dean, its just not available.  I'm unsure of v14 considering its extremely old, not serviced or rarely used.  Get used to .1mm being the finest you're going to achieve or put in a suggestion to reduce minimum to .05
#16 Richard Rubinski
  • 693 posts
Posted 07 December 2021 - 02:26 PM
That’s strange that they have .1mm which is (0.00393701) and not be able to do .05
#17 Dean Downey
Dean Downey
  • 40 posts
Posted 07 December 2021 - 09:05 PM
No worries! I certainly can live without it but definitely liked having that feature. (It was in my old version 2014) not v14 which is quite older.
More so just looking at complex elevations in pdf format with the paint areas being a smaller line thickness than the windows, railing, etc.
It gave better contrast IMO.
When printing at 1/4" scale you could see a noticeable difference.
Funny that the option is there (.05) but not executable in the output.
Thanks for looking into it.
  • Gary McKeon likes this
Dean Downey
dmdhomeplans.com
#18 Joseph Smith
  • 853 posts
Posted 08 December 2021 - 04:05 PM
Sorry but I'm seeing the smallest pen possible to assign at .10mm.
Please show me .05
#19 Jon Davis
Jon Davis
  • 543 posts
Posted 09 December 2021 - 09:34 AM
Please show me .05
You have to type it in manually.
#20 Joseph Smith
  • 853 posts
Posted 09 December 2021 - 12:51 PM
ya, it allows .01mm manual entry also but clearly not reasonable.  i think its safe to say .1mm is the smallest we'll see.
