parapet wall on gable end
gable parapet modern contemporary
8 replies to this topic
#1 Mark Gradison
Mark Gradison
  • 18 posts
Posted 17 December 2021 - 11:17 AM
Does anyone know how to create a gable end like shown in the photo?
#2 Joseph Smith
  • 853 posts
Posted 20 December 2021 - 12:30 PM
Few different ways i'm sure. My procedure below.
I used a secondary roof planes with higher heel, trace roof hole from the main roof around face wall and deselect cleanup on the wall.  I used a custom wall for the upper wall w/stone on inside and outside so it covers the wall ends.  I also use a custom beam rather then stone cap on the upper custom wall because the custom wall cap stupidly stops short of the wrapping stone. (fit beams to raised roof planes then deselect cleanup on those custom beams)
Once you're happy with the look, deselect cleanup everywhere just for safety then delete the raised roof plane.
You appear to be a new SP user so prepare yourself or a little trial and error to get it to work perfectly.
That sure is a beautiful look you're going for!!
#3 Richard Rubinski
  • 695 posts
Posted 21 December 2021 - 12:10 PM
Joseph, have you tried the Parapet Wall feature in 2022?
#4 Joseph Smith
  • 853 posts
Posted 21 December 2021 - 01:00 PM
No.  i've never had the need to do a parapet wall, perhaps it'll work in Marks situation.
#5 Richard Rubinski
  • 695 posts
Posted 22 December 2021 - 07:41 AM
I just thought you might have experimented with it.
#6 Brendan Smythe
Brendan Smythe
  • 87 posts
Posted 19 January 2022 - 02:23 PM
Joseph, how did you get your illustrated look in your rendering examples? You must have changed the settings to get it to look softer, could you share those settings?
Thank you!
#7 Fred Dickson
Fred Dickson
  • 279 posts
Posted 19 January 2022 - 03:44 PM
Attached File  Plan View .jpg   30.47KB   1 downloadsAttached File  Rendered View.jpg   121.1KB   2 downloadsYou could also use a beam (hidden and not displayed) for your gable roof reference with no overhang and use a solid masonry wall.  I used the brick retaining wall.  Then adjust the brick wall with top of wall edit.
  • Chris Proost and Mike Adams like this
#8 Mark Petri
  • 1,872 posts
Posted 19 January 2022 - 03:54 PM
You can also set the gable to a negative overhang, so it can still reference the gable parapet and sit behind the wall.
  • Mike Adams likes this
#9 Keith Almond
  • 5,303 posts
Posted 19 January 2022 - 07:19 PM
Thank you!
Joe already shared his settings in this https://softplan.com...ode/#entry22413 thread.
Also tagged with one or more of these keywords: gable, parapet, modern, contemporary
