MULTIPLE MATERIALS ON A GABLE END
GABLE MATERIAL
9 replies to this topic
#1 JOSHUA YOUNG
JOSHUA YOUNG
  • 5 posts
Posted 29 February 2024 - 06:30 PM
What is the best way to go about getting two different materials on a gable end. For instance, lap siding on the wall that goes up the gable about half way then the upper part of the gable would be b&b. I know I can do one material on the wall and another on the gable but I want the material transition a little higher than the plate line like the sketch attached.
#2 Sam Morgan
  • 980 posts
Posted 29 February 2024 - 07:16 PM
I do it with solids
  • 5,552 posts
Posted 29 February 2024 - 08:34 PM
I normally do it with a separate wall. Just Siding. Hidden in plan, and just slightly in front of the plan wall. Set height you want and fit to roof.
  • Steven Wohlgemuth and Gary Wicklund like this
#4 David Zawadzki
  • 780 posts
Posted 29 February 2024 - 09:04 PM
Isn’t there a way to edit transition height?
Twinmotion 2024, D5 Render, Autocad, SoftPlan 2026, Solidbuilder, Chief Architect X15, Sketchup, 3D Home Architect, etc.
#5 Philip Frank
  • 581 posts
Posted 01 March 2024 - 04:46 AM
Edit the gable end roof edge and see attached. The "Height" is the distance from the peak to where the transition occurs.
  • Wesley Penner, RUSSELL LITTEN and David Zawadzki like this
#6 Bill Wimberley
Bill Wimberley
  • 694 posts
  • LocationSan Angelo, TX
Posted 01 March 2024 - 12:19 PM
Edit the wall and give it the desired height.
Edit the wall and select the Top of Wall tab. Select Clip to Roof to trim off the portions of the wall that are protruding through the roof.
Edit the gable and select Gable End Provided by Roof. Set the gable end to the desired material.
  • Jim Johnson likes this
#7 Allen McDonnell
  • 1,212 posts
Posted 01 March 2024 - 12:30 PM
Many ways to skin the cat with this one!
  • 5,552 posts
Posted 02 March 2024 - 03:56 PM
Doesn't adjusting the height upwards, leave a gap between the top of the wall and the gable end provided by roof? It seems to when I've used it.
#9 Philip Frank
  • 581 posts
Posted 04 March 2024 - 07:16 AM
No it does not leave a gap. It moves the transition between the 2 type of wall materials to the indicated "Height" from the peak.
  • RUSSELL LITTEN and John Jones like this
#10 Keith Almond
  • 5,552 posts
Posted 04 March 2024 - 07:31 AM
Thank you ... I'll have to look at it again.
Also tagged with one or more of these keywords: GABLE, MATERIAL
