softplan crashing windows
14 replies to this topic
#1 ed sloot
ed sloot
  • 24 posts
  • LocationGuelph Ontario
Posted 23 January 2022 - 08:58 AM
need some help with the computer crashing while in softplan 2022. I have asked for help from tech support at softplan itself but get the same answer that windows 10 is fighting with softplan for control of the graphics driver and thats as much as i can get from anyone.
It's very annoying in not only the system shutting down and re-booting, it dosnt always restore the drawings to the last item edited or drawn. it also loses all the passwords and login info for every other program on the laptop ( iS-7300HQ CPU @2.50 GHz  16.0 GB, 64 bit
it seems if windows controls the driver it wants it causes softplan to have a fatal error and send a report to them. If i switch the driver to use the softplan suggested Nvida GS driver then windows crashes. there is no specific process in progress when either of these situations occur.
none of this happend with the old HP Inspirion which wasnt using windows 10 but had fallen off the desk once too often so upgraded and now its been an issue since
#2 David Franz
David Franz
  • 12 posts
  • LocationCleveland,Ohio
Posted 23 January 2022 - 09:18 AM
following
David Franz
Wood Tech Builders LLC
member Greater Cleveland HBA
  • 5,301 posts
Posted 23 January 2022 - 10:46 AM
What are the graphics. Does it have onboard and dedicated graphics?
#4 David Zawadzki
  • 733 posts
Posted 23 January 2022 - 11:38 AM
Are you using one of these cards?
What type of video card does SoftPlan require? | SoftPlan home design software
#5 ed sloot
ed sloot
  • 24 posts
Posted 24 January 2022 - 07:07 AM
hmmmm.. it is suppose to be set on high performance: NVIDA GeForce GTX 1050.
how do i find how to tell if anything is dedicated or on board???
  • 5,301 posts
Posted 24 January 2022 - 08:08 AM
The GTX 1050 is a dedicated card.
In the 3D model, go to HELP > INFORMATION The RENDERER tab should shown what graphics are performing the render. It may say INTEL HD XXXXXX which is the onboard chip graphics.
#7 ed sloot
ed sloot
  • 24 posts
Posted 24 January 2022 - 05:50 PM
Hi Keith. It says Direct X 11 renderer.
Feature level= 11.0
Dedicated video memory=4021 MB
Dedicated system memory=0MB
Shared system memory=8123 MB
shader version=66.1
processors=4
What ever that all means is beyond my simple skills
#8 ed sloot
ed sloot
  • 24 posts
Posted 24 January 2022 - 05:53 PM
Davis i see on your post i need 1 GB of Ram but it tells me there is zero. where can i change that or ?????
#9 Keith Almond
  • 5,301 posts
Posted 24 January 2022 - 08:11 PM
If I remember correctly, you have to go into the NVIDIA control panel and tell it that Softplan has to use the NVIDIA CARD.
  • Steven Wohlgemuth and ed sloot like this
#10 Keith Almond
  • 5,301 posts
Posted 25 January 2022 - 06:55 AM
3D window HELP > INFORMATION on my Machine give this:
Attached File  2022.01.25_07h45m59s_001_Information.png   16.28KB   0 downloads
Whether you have additional integrated graphics depends on your chipset. Typically INTEL CPU's also incliude integrated graphics. Again, typically AMD chipsets don't. If you have an AMD chipset you may only have one graphic choice so it may not even show up separately.
If your computer has two graphic options, it may be worth checking/forcing your machine to use the NVIDIA option for Softplan.
Attached File  2022.01.25_07h47m09s_002_.png   389.91KB   0 downloads
#11 ed sloot
ed sloot
  • 24 posts
Posted 25 January 2022 - 07:18 AM
it tells me there i have 0 games and apps and clicking the green title to view supported apps and games does notta! it indicates it checked 13 hours ago but i have no idea what it checked for ????  i will keep trying to figure that out
#12 Keith Almond
  • 5,301 posts
Posted 25 January 2022 - 07:38 AM
That's probably NVIDIA GeForce Experience, and it would be checking for updates.
You have to go to NVIDIA CONTROL PANEL.
#13 ed sloot
ed sloot
  • 24 posts
Posted 26 January 2022 - 07:16 AM
I finally got the machine to go there and i made the change so hopefully that does the trick. Thanks Keith for your patience
#14 Keith Almond
  • 5,301 posts
Posted 26 January 2022 - 08:49 AM
You're welcome Ed.
Let us know if this actually works for you, and solves the problem.
#15 ed sloot
ed sloot
  • 24 posts
Posted 26 January 2022 - 10:25 AM
Thanks Keith. so far so good. It would have crashed by now as this is the longest i have been able to draw without some sort of crash from either windows or softplan itself. I will send the info to Colin as he was trying to figure out what the problem was aswell
