Line thickness change
#1 Guest_James J. Hamrick_*
Posted 29 April 2022 - 02:20 PM
Hey everyone. My name is James.
I have a later version of Softplan, -13. I have yet to find a way to change the thickness of my lines, to make them bolder when needed.
Is there such an adjustment?
#2 Bill Wimberley
Bill Wimberley
  • 439 posts
  • LocationSan Angelo, TX
Posted 30 April 2022 - 05:46 PM
https://softplantuts...rint-Pen-Styles
  • 5,021 posts
Posted 01 May 2022 - 08:16 AM
Yes in the print pen setup. Set your PENS to the thickness you require and adjust the pen for each component as necessary.
See also this post ... https://softplan.com...t-pens/?p=11298
#4 Gary Wicklund
Gary Wicklund
  • 130 posts
  • LocationDuncan BC Canada
Posted 01 May 2022 - 07:25 PM
You can also change the width of your line and make it solid, I use this a lot instead of pen weights as pen weights don’t always show up on the screen
I use 1/2” for most bold lines and 1 1/2” for grade lines but you can experiment
Once you set one line you can use repeat edit to change more
I find if I use pen weights I always miss an edit or something else shows up bold when I print it when I don’t want it to be.
my 2 cents
