Would anyone have an interior shiplap texture they would be willing to share? I would like to show a shiplap finish on a ceiling, and while you can use a profile on walls, you can't on ceilings.
Posted 18 January 2023 - 08:59 AM
There are two textures that SoftPlan provides that I have been using as placeholders until I can find other textures to import. When in 'Surface Edit, go to 'Manufacturer', under 'Armstrong' and expand 'Ceilings', navigate to the WoodHaven Collection. There you will see the Beadboard - 1149 texture and the White - 1148 texture. Both of these textures are what I found to look the closest to white shiplap that I place on ceilings. Adjust the scale of the textures under the 'Options' tab to get the desired look and make sure 'Maintain Aspect Ratio' is checked so that the textures scales to size and does not stretch. I myself will also be working with a lot of shiplap, so I may be either reaching out to manufacturers to see if they can provide a seamless texture or creating it myself through photo scanning or with a texturing software. Hopefully these can suit your needs in the meantime as it does for me. ![]()
Also tagged with one or more of these keywords: shiplap texture, shiplap, texture
Guest Area →
Guest Questions →
Changing Color of a TextureStarted by Greg Keeler , 07 Dec 2024 |
SoftPlan →
General Questions →
"Paint" textures not appearing in created symbol?Started by Jay Johnson , 27 Jul 2024 |
SoftPlan →
General Questions →
Fascia Texture OrientationStarted by Jay Johnson , 23 Jun 2024 |
SoftPlan →
General Questions →
Custom Colors and TexturesStarted by Jeff De Kam , 14 Sep 2023 |
Guest Area →
Guest Questions →
3D MATERIAL TEXTURESStarted by CHUCK PRESTON , 11 Apr 2022 |
