Changing Color of a Texture
Rendering Texture Color
#1 Greg Keeler
Greg Keeler
  • 1 posts
Posted 07 December 2024 - 08:00 AM
I am doing a very simple rendering in which I have lap siding on 3 sides of the building, but B&B siding on one side. I've chosen a B&B texture from the stock texture files, but it is beige (or unfinished wood) color, and I want it blue to match the lap siding. When I've tried to change the color, the surfaces appear as flat with no textural relief. How can I change the color of that texture and maintain the depth/relief of it?
#2 Wesley Penner
Wesley Penner
  • 53 posts
  • LocationMaricourt, QC, Canada
Posted 08 December 2024 - 05:51 AM
Is it possible that on your blue wall you have a profile assigned in the wall definition? And that on the front wall you do not have a profile? There are two ways that you can have a "profile" look: (1) With textures (bitmaps, jpeg's assigned in 3d mode) that have the look of the profile (2) With a profile assigned in the wall def and a solid color texture assigned.
You seem to be a member of the forum. It would be better and you would receive faster responses if you post in the General part of the forum.
#3 Fred Dickson
Fred Dickson
  • 319 posts
Posted 08 December 2024 - 02:32 PM
Rt Click the surface in the 3D mode>Surface Edit>Lighting>Depth Relief & increase it.  Should do it.
#4 Todd Williard
Todd Williard
  • 251 posts
  • LocationPA
Posted 09 December 2024 - 01:10 PM
I think this video will explain how to do it.
https://www.youtube....h?v=fL4kgj-aiHI
V11-V2026
#5 Guest_Amy_*
Guest_Amy_*
Posted 08 May 2025 - 02:45 PM
I have watched and read all this and my still does the same thing. I have changed the depth relief but the siding is still so light unless you zoom right up to the siding you can not see it.
Any additional information available?
  • 5,534 posts
Posted 09 May 2025 - 08:19 AM
Try adjusting the Ambient and Diffuse lighting settings until you get something suitable.
Also tagged with one or more of these keywords: Rendering, Texture, Color
