I am drawing a 60x100 shed, and trying to represent all of its components to help an estimator learn what goes into this type of building.
I need a draft stop (OSB, drywall, etc nailed to a truss) in the center of the building). I have an "OSB only" wall drawn in the correct position, but it doesn't show up in 3D textured or in 3D framing.
I've tried setting my wall definition to use "Oriented Strand Board", "Sheathing", "Plywood".
I've opened "Extraction Options" and "Materials" in both modes and can't seem to get the material turned on.
I ensured that "extract in model" is turned on.
I've messed with layers/building options.
What simple thing am I missing?
The only reason I care this much is I'm also trying to work my way into correctness of the model, with a view to using SoftList.
It does report to SoftList correctly, so I know it's in the model....it just doesn't render.
Derk
