I am trying to create a visibility setting for Roof Plans, without the framing included. This is what I have turned on and what I am getting. Can anyone tell me what I am doing wrong to get the outcome I am wanting?
Posted 10 September 2023 - 02:56 PM
I don't think I ever changed the visibility for the roof pitch but could it apply to the elevations? To check if the drawing is actually updating try turning on "roof outline dashed" in the visibility. I know this effects the roof layout because I use it sometimes.
Posted 10 September 2023 - 03:18 PM
This is how I do it: First create your roof and add just one framing member. A single rafter will do. Go to roof options and make sure "include walls" is checked and then Generate Drawing. I save it as Roof Wall Layout, but whatever. Next from the elevation tab save the top elevation. I save this as Roof Plan. Merge the Roof Wall Layout to this plan and you can erase any framing or walls you want. Sometimes they don't align if your References aren't there but you can add a reference point by doing undo merge and add them to get the alignment you need. After that is done you can add any notes you want or what ever you need. I have attached a sample.
Also tagged with one or more of these keywords: Visibilities, Roof
Raise Roof - Window Pediment Clearance, Heel Height, Knee WallStarted by Steve Gray , 08 Feb 2024 Roof, Knee Wall, Raise Roof and 1 more... |
Roof SettingsStarted by Mark Petri , 11 Dec 2023 Roof, Settings, Project Settings and 2 more... |
How to Model Roof CablesStarted by Verlin Klassen , 15 Mar 2023 Cable, cables., roof cable and 2 more... |
Pointed GableStarted by Wendall Hilty , 14 Dec 2022 Gable, Roof, Angle, Pointed, edge |
SoftPlan version 2020 →
Roof Design / Cross SectionStarted by Jason Ball , 04 Dec 2022 roof, cross section and 1 more... |
