I am trying to add an exterior door with a sidelight to my drawing with a 48" long window in the door and the sidelight. I have a similar door in my openings library, but the window inserts are only 36" long. What is the best way to create a door with the windows I need?
Change Door Window Insert Size
Started by
Verlin Klassen
, Feb 17 2016 03:32 PM
openings Door inserts edit openings
Posted 17 February 2016 - 07:47 PM
Draw it ...
Have a look at this thread ... http://softplan.com/...-entrance-doors
I'm not at a Softplan computer at the moment, but basically, draw the door frame, draw the glazed insert, and add all the detail you wish with lines and arcs.
Use the same procedure as the custom garage door here ... http://softplan.com/...pening-tutorial
If anything is still unclear, post a picture of the door, and I'll do a step by step tutorial.
Also tagged with one or more of these keywords: openings, Door inserts, edit openings
SoftPlan →
General Questions →
Help Requested / DrawingStarted by Kristy Hawkins , 28 Jan 2021 ![]() |
SoftPlan →
SoftPlan 2018 →
Stop Opening ID change suggestionsStarted by Mark Petri , 14 May 2018 ![]() |
SoftPlan →
SoftPlan 2018 →
Trim Messed UpStarted by Mark Petri , 16 Aug 2017 ![]() |
SoftPlan →
SoftPlan 2018 →
Trim, Siding and other things.Started by Mark Petri , 16 May 2017 ![]() |
SoftPlan →
SoftPlan 2016 →
3D Openings in Bearing WallsStarted by Verlin Klassen , 16 Jun 2016 ![]() |
