3C582-03.pdf 457.91KB 225 downloads I have a exterior wall with brick veneer. When I create a slab plan I use the floor mode and put a structural slab in. I would like the slab to go to the exterior of the brick to dimension it correctly for a brick ledge. However if I make the brick bearing, my area will pull to the outside of the brick and give me a false reading on the square footage. I can not figure out a way to have the slab pull to the brick but not interfere with area, roof, etc. Has anyone else come up with a way? I don't create any separate drawing for my slabs as I dimension and note directly on to the floor mode (see attached).
Posted 18 March 2015 - 09:39 AM
I have walls that have brick and the brick is not set as bearing. If I draw the automatic slab in floor system, as soon as I modify it to structural, it attaches to the outside of the brick. When I do area and attach to outside of bearing, it excludes the brick.
Also tagged with one or more of these keywords: brick, foundation, area
SoftPlan →
General Questions →
Room area on room finish ScheduleStarted by Wesley Penner , 18 Nov 2020 Room, Area, Finish schedule |
SoftPlan →
General Questions →
Poured Foundation DetailStarted by Bruce Roorda , 24 Sep 2019 Details, Foundation, Siding and 1 more... |
SoftPlan →
SoftPlan version 2020 →
2020 Area CrashStarted by Scott Gunnufson , 04 Apr 2019 Area, Interior edge |
SoftPlan →
General Questions →
Creating New Texture FilesStarted by James Ronson , 22 Oct 2018 Siding, Stone, Brick |
SoftPlan →
SoftPlan 2018 →
Corbelled Gabel Ends OversailingStarted by Kris Blalock , 28 Sep 2018 gable, brick, details, 3D |
