Not sure what happened..
I didn't do anything different. Was just doing notes and little edits.. Went to view my 3D and this is now how it appears ??
Posted 25 May 2017 - 05:33 AM
Is it possible that you turned textures off through the Textured menu? I can post a screenshot later of the menu, but I believe it's under face options or renderer.
Another way to test this would be to switch to Ray Trace and see if the textures show up.
If that doesn't work then it might have something to do with the folder where your textures are located. Did you move files recently? I've have this happen when I moved from my "C" drive to my "D" drive due to space issues. I had to change the folder locations through the System options.
If you cannot discover a way to fix, I suggest updating your video card driver before you issue a help ticket.
Posted 25 May 2017 - 06:57 AM
Hi Derrik,
I've checked and my textures is on. As well as ray trace it still just shows up colours. I have not moved any files recently so I'm rather clueless as to what went wrong. I was working in the drawing, the 3D was fine. Then I went back to it a few minutes later and that's what it looked like.
SoftPlan →
SoftPlan version 2020 →
NEED FREELANCERS FOR PER DIEM WORK GREAT PAY!Started by Randy King , 25 Jan 2021 ![]() |
SoftPlan →
3D printing questions - anyone else 3D printing designs?Started by Mike Smith , 10 Oct 2020 ![]() |
SoftPlan →
Textures in renderingsStarted by Mark Petri , 18 Feb 2020 ![]() |
SoftPlan →
Lost most 3d infoStarted by Clint Hiebert , 09 Jan 2020 ![]() |
Guest Area →
Guest Questions →
Does 2020 do "fly thru" videos?Started by Glenn Mitchell , 02 Dec 2019 ![]() |
