Vinyl Corners
Vinyl Corners Siding Vertical Trim Cladding exterior
#1 Shay Bashaw
Shay Bashaw
  • 29 posts
Posted 25 March 2018 - 07:05 PM
Does anyone have an easy way to add the typical vertical corners to horizontal vinyl siding in the 3D model?
I am not seeing an easy way to do this.
See the attached image.
In reality, the horizontal siding material does not just magically join together around the corners.  There is a vertical strip to conceal the ends of the horizontal material.
Thanks!
#2 Daniel Zanoli
Daniel Zanoli
  • 228 posts
  • LocationNorthern Michigan
Posted 25 March 2018 - 07:19 PM
Trim end options when you edit your wall
#3 Tom Rogers
  • 1,110 posts
Posted 26 March 2018 - 08:17 AM
you can select to use corner boards.  If you are using material list you can adjust the formula.  If just 3D it looks fine, just adjust size based on your trim
"remember... what we are building today, should be what we want in the future"‚Äč
www.arcresidential.com
#4 Shay Bashaw
Shay Bashaw
  • 29 posts
Posted 26 March 2018 - 06:32 PM
Awesome,
Thanks Daniel and Tom!
Also tagged with one or more of these keywords: Vinyl, Corners, Siding, Vertical, Trim, Cladding, exterior
