I have a customer who wants a poured foundation walkout wall with 3 foot high brick veneer and siding above it to match up with the framed structure siding above, on their new home design. I'm looking for examples/solutions for a construction drawing wall detail which would cover concerns with matching up with the framed structure siding above, and compliance with IBC 2015. The interior of the walls are to be unfinished concrete and each exterior end of the walkout wall will have block retaining walls for the walkout grade change.
Poured Foundation Detail
Posted 24 September 2019 - 07:21 PM
If you google brick and siding wall section details you ought to be able to find something. Typically brick veneer is not bearing. So, to draw it, you could probably find an existing wall definition with brick veneer skirting and wood siding above and add the partial foundation wall underneath to support the framed wall behind the brick on a ledge. Just adjust the offsets and add the height of concrete wall you want. Or, set a brick veneer wall on your walk-out foundation and adjust the height of brick to your specs, adding siding above the brick.
For instance, this wall could be sitting on the slab/walk-out foundation...
http://www.huberwood...rary/48/355/357
Or you could do this detail with siding furred out below the main floor system to top of the brick transition...
https://www.greenbui...igid-insulation
Or...
https://foundationha...ete-brick.shtml
or...
https://masonryinfo....er.original.pdf
- Bruce Roorda likes this
Posted 24 September 2019 - 08:25 PM
Those are some helpful links Mark. On this particular project, there would be a 9' poured foundation wall of the basement space which supports the wood truss floor and framed exterior walls above. The 3 foot high brick is decorative non bearing. So the challenge is installing exterior insulation to code on the exterior of the poured wall and then attaching siding above the 3 foot high brick wall where the poured wall is. Once above the poured wall, the detail would be a typical framed wall and siding section detail.
#8
Posted 25 September 2019 - 07:40 AM
We've done an earth berm house where the owner wanted exposed concrete inside, so all insulation was outside the poured concrete. For the above grade finish they wanted a cement based stucco. So, we came up with a solution with rigid insulation fastened to the concrete and layers of fiber mesh, wire lath, etc. that worked to add all the insulation and finishes outside. ICF walls would be best, but furring strips and rigid insulation outside could work. Or, check out the ZipSystem insulated sheathing and ask a local rep about fastening to the concrete.
Also tagged with one or more of these keywords: Details, Foundation, Siding, IBC2015
SoftPlan →
SoftPlan 2024 →
Standard Details and NotesStarted by Gainer Nissen , 14 Feb 2024 details, notes |
SoftPlan →
SoftPlan 2024 →
Siding Profiles Visible on Live ElevationsStarted by Mike Miller , 24 Jan 2024 siding, elevation, profile |
Guest Area →
Guest Questions →
Plan Set detailsStarted by Alan Baas , 21 Sep 2023 plan set, rooms, details |
SoftPlan →
SoftPlan 2022 →
Control over Individual MaterialsStarted by Derk Burgers , 21 Sep 2022 siding, adjust wall material and 2 more... |
SoftPlan →
SoftPlan 2022 →
Board and Batten AlignmentStarted by Wendall Hilty , 31 May 2022 surface, board and batten and 6 more... |
