Pole Barn Wall Does Not Show Up in Wall
Walls
#1 Elise Musumeci
Elise Musumeci
  • 1 posts
Posted 13 January 2020 - 12:24 PM
Could somebody please advise me on how I can add the Pole Barn Wall to my Wall List?  I've tried everything according to the directions and the wall will NOT show up in my list at all!  Thank you!
#2 Kevin Rabenaldt
Kevin Rabenaldt
  • 391 posts
  • LocationSan Antonio
Posted 14 January 2020 - 12:52 PM
Are you creating it under Drawing or System?  If under System, then it won't be available until you create a new drawing I believe.
#3 Michael Roman
Michael Roman
  • 121 posts
  • LocationPeshtigo, WI
Posted 16 January 2020 - 06:42 AM
If you did create it in the System Options then you can get it into your drawing by resetting the drawing to the system wall library.
Go to Drawing Options>Drawing Options>Define Wall.  On the right you will see 'Reset To Drawing Template'.  Make sure the radio button for system is active and click 'Reset".
The wall should now be in your drawing wall list.
Posted 16 January 2020 - 11:10 AM
Easier (SAFER - in case like me you create custom walls in drawings), you go to the system wall library, EXPORT the wall you just created. Then in the drawing library, IMPORT the same wall.
  • Steve and Carla Farnam and Michael Roman like this
Also tagged with one or more of these keywords: Walls
